I am trying to read leak test data from a NOLEK S9 unit but i cannot appear to get this setup correctly.
I am using a serial node with the following
Baud rate: 9600
Data bits: 8
Stop bits: 2
Parity: None
Flow: none
Serial port : /dev/ttyS2:9600-8N2 (For COM port 1 on the IOT2040)
Node red v1.2.1 is running on a siemens IOT2040, (I know it is an older version, but the IOT2040 does not want to run anything more up to date)
Any Info on how to request data from the NOLEK unit would be greatly appreciated
is Node RED running in some type of container?
where the physical hardware isn't present in it's virtualised env?
Also check the credentials of the entity running Node RED, it may not have the rights to see ports (add it to the dialout group perhaps. -if its related of course)
I don't do (or work) on these things - but food for thought
There are both, i have a /dev/ttys2 and also /dev/ttyS2
I believe if i short pin 2 and 3 on the serial cable, any message sent out will be returned?
Is that a way to check if the com port is setup correctly?
What does ls -l /dev/tty[sS]2 show? Please copy the output and show us.
This is an example from my Debian PC crw-rw---- 1 root dialout 4, 66 Jun 27 15:54 /dev/ttyS2
As I understand it, a serial port should be a character special device, so the first character of the output should be 'c'.
Also I would expect it to have a capital S (though I don't know if the Siemens IOT2040 follows this convention).
If the /dev/ttys2 line begins with '-' then it is a normal not a character special file and was probably created in error.
