Hello. Since few days, i've problem with Power State Node (out). I've good result payload, but the device (sonoff) doesn't work. Where could the problem be?
From the info i have seen, Sonoff have restricted the API to paid accounts. Or the latest update has broken the API.
You can query info but all actions do not work, nor does the device activity. I have a work around via alexa (if you use it).
I have the same issue. I also though about restriction to paid accounts, but js using ewelink-api works just fine.
Any idea?
I think it would take developer help.
