Hi Marci,
what I meant, is how did you update Node-RED on the Ubuntu environment?
Hi Marci,
remove the old-one first : sudo apt-get remove nodejs
and then install the new one : sudo apt-get -y install nodejs
that's it
nodejs != Node-RED.
Hopefully you can sudo apt-get remove nodejs and then run the Node-RED upgrade script
https://nodered.org/docs/getting-started/raspberrypi - which will install a LTS version of nodejs and then Node-RED.
All your work will be in your ~/.node-red directory - so back that up just to be sure -but the script doesn't touch it so it should come back ok.
Thanks marci and dceejay,
I am just VERY, VERY cautions as I can not be without the server.
It controls too many Solar production, heaters and lights at the moment and I HAVE to upgrade to be able to use a subflow to restrict heater to only switch on during office hours.
I am considering to follow this cheat sheet
