Hey, so basically im new with all this, im using the Raspberry Pi 4 and im trying to install node red, and I can't install it in the terminal of the Pi 4 just appears the imagem down below and nothing else.
Use the full command as specified in the official docs...
bash <(curl -sL https://raw.githubusercontent.com/node-red/linux-installers/master/deb/update-nodejs-and-nodered) --node16
Note. I added the --node16 to save you missing that part
Ps, you missed the last ) in your screenshot
You can post the install log that it mentions there. When posting please copy/paste rather than screen shot.
First though, make sure that this works
sudo apt update && sudo apt full-upgrade
If that doesn't work then the script will fail.
