Hello, good morning,
I just update to the nodered version 16.0.0 and I lost all flows, all is empty, do you know how an update can remove all flows?
is any way to recover it?
thanks in advance.
thanks in advance.
Hello @kerontide, welcome to the forum.
There is no such thing as Node-red version 16.0.0, the current version is 3.1.0.
Perhaps you have Node-red installed in/with Home Assistant? If so I can't advise you.
If you just have Node-red, go to your .node-red folder and look for files named something.json
I think at one time the default name for the flows file was flows_hostname.json but now I think it is flows.json (there is also a flows_hostname_cred.json (?) or flows_cred.json)
If you have the older version you can just rename these two files. (make a backup first!)
thanks a lot!!! yes you are right I have node-red under HA.
Thanks a lot it helps me and sorry about the inconveniences.
