Previously i was sending over someone data with the OPCUA-IIoT-Flex-Server contained in the node-red-contrib-lativ content package
I couldn't install this package after update
I get errors shown below
incompatible with your node/npm version: node-red-contrib-lativ@1.0.3
ERR! notsup Actual: {"npm":"8.5.0","node":"v16.14.2"}
How do i resolve this problem
last state of used intallation
Node-red = v2.2.2
nodejs = v17.7.1
npm = 6.14.16
Best regards
Drop your nodesjs version back to node16
I was try this command.
#sudo npm install -g n
#sudo n 16.14.2
Resul is same:(
Blockquote
ERR! code EBADENGINE
2022-03-21T06:55:28.684Z [err] npm ERR! engine Unsupported engine
2022-03-21T06:55:28.684Z [err] npm ERR! engine Not compatible with your version of node/npm: node-red-contrib-lativ@1.0.3
2022-03-21T06:55:28.684Z [err] npm ERR! notsup Not compatible with your version of node/npm: node-red-contrib-lativ@1.0.3
2022-03-21T06:55:28.684Z [err] npm ERR! notsup Required: {"node":"8.x || 10.x"}
2022-03-21T06:55:28.684Z [err] npm ERR! notsup Actual: {"npm":"8.5.0","node":"v16.14.2"}
Blockquote
I review supported node version
Requried node version 8.x || 10.x not compatible with 2.2.2
https://nodered.org/docs/faq/node-versions
Oh crikey. I see from that error it is wanting node 8 or 10. They are both well out of support so really you need to contact the owner of that node to see if they will update it. If not then I’d suggest not using it rather than going back to node 10.
There are other Opcua nodes available
Unfortunately, this package has no repo on github and its github link points to biancode/node-red-contrib-iiot-opcua
biancode took down "biancode/node-red-contrib-iiot-opcua" package sometime back (cant remember reason why now but it is now gone)
