Sorry i was thinking a line chart, you could simulate a bar chart using a stepped line chart and fill
e.g.
[{"id":"fddda58d47a6f382","type":"function","z":"b9860b4b9de8c8da","name":"mm Rainfall (next hour)","func":"var m = {};\n\nm.data = [[]]\nm.data[0] = msg.payload.minutely.map(a => a.precipitation);\nm.labels = []\n\nfor (var i = 0; i < m.data[0].length; i++) {\n m.labels.push(i % 10 === 0 ? i : \"\")\n}\nm.series = [\"Rain\"];\n\nmsg.ui_control = {\n \"options\": {\n \"elements\": {\n \"line\": {\n \"stepped\": true,\n \"borderWidth\": 1,\n \"fill\": true,\n \"backgroundColor\": \"blue\"\n },\n \"point\":{\n \"radius\": 0\n }\n }\n }\n}\nreturn { payload: [m], topic: msg.topic, ui_control: msg.ui_control};\n","outputs":1,"noerr":0,"initialize":"","finalize":"","libs":[],"x":490,"y":4860,"wires":[["346cbf054655cf12","3f4fda4b63dd90c7"]]},{"id":"dfc23fd9b521cb47","type":"inject","z":"b9860b4b9de8c8da","name":"dummy next-hour rain data","props":[{"p":"payload"},{"p":"topic","vt":"str"}],"repeat":"","crontab":"","once":false,"onceDelay":0.1,"topic":"","payload":"{\"lat\":51.4965,\"lon\":-0.2737,\"timezone\":\"Europe/London\",\"timezone_offset\":3600,\"current\":{\"dt\":1687800506,\"sunrise\":1687751111,\"sunset\":1687810942,\"temp\":22.01,\"feels_like\":21.44,\"pressure\":1020,\"humidity\":45,\"dew_point\":9.54,\"uvi\":0.93,\"clouds\":0,\"visibility\":10000,\"wind_speed\":5.66,\"wind_deg\":290,\"weather\":[{\"id\":800,\"main\":\"Clear\",\"description\":\"clear sky\",\"icon\":\"01d\"}]},\"minutely\":[{\"dt\":1687800540,\"precipitation\":0},{\"dt\":1687800600,\"precipitation\":10},{\"dt\":1687800660,\"precipitation\":20},{\"dt\":1687800720,\"precipitation\":30},{\"dt\":1687800780,\"precipitation\":40},{\"dt\":1687800840,\"precipitation\":50},{\"dt\":1687800900,\"precipitation\":60},{\"dt\":1687800960,\"precipitation\":70},{\"dt\":1687801020,\"precipitation\":80},{\"dt\":1687801080,\"precipitation\":90},{\"dt\":1687801140,\"precipitation\":100},{\"dt\":1687801200,\"precipitation\":110},{\"dt\":1687801260,\"precipitation\":120},{\"dt\":1687801320,\"precipitation\":0},{\"dt\":1687801380,\"precipitation\":0},{\"dt\":1687801440,\"precipitation\":0},{\"dt\":1687801500,\"precipitation\":0},{\"dt\":1687801560,\"precipitation\":0},{\"dt\":1687801620,\"precipitation\":0},{\"dt\":1687801680,\"precipitation\":0},{\"dt\":1687801740,\"precipitation\":0},{\"dt\":1687801800,\"precipitation\":0},{\"dt\":1687801860,\"precipitation\":0},{\"dt\":1687801920,\"precipitation\":0},{\"dt\":1687801980,\"precipitation\":0},{\"dt\":1687802040,\"precipitation\":0},{\"dt\":1687802100,\"precipitation\":0},{\"dt\":1687802160,\"precipitation\":0},{\"dt\":1687802220,\"precipitation\":0},{\"dt\":1687802280,\"precipitation\":0},{\"dt\":1687802340,\"precipitation\":0},{\"dt\":1687802400,\"precipitation\":0},{\"dt\":1687802460,\"precipitation\":0},{\"dt\":1687802520,\"precipitation\":0},{\"dt\":1687802580,\"precipitation\":0},{\"dt\":1687802640,\"precipitation\":0},{\"dt\":1687802700,\"precipitation\":0},{\"dt\":1687802760,\"precipitation\":0},{\"dt\":1687802820,\"precipitation\":0},{\"dt\":1687802880,\"precipitation\":0},{\"dt\":1687802940,\"precipitation\":0},{\"dt\":1687803000,\"precipitation\":0},{\"dt\":1687803060,\"precipitation\":0},{\"dt\":1687803120,\"precipitation\":0},{\"dt\":1687803180,\"precipitation\":0},{\"dt\":1687803240,\"precipitation\":0},{\"dt\":1687803300,\"precipitation\":0},{\"dt\":1687803360,\"precipitation\":0},{\"dt\":1687803420,\"precipitation\":0},{\"dt\":1687803480,\"precipitation\":0},{\"dt\":1687803540,\"precipitation\":0},{\"dt\":1687803600,\"precipitation\":0},{\"dt\":1687803660,\"precipitation\":0},{\"dt\":1687803720,\"precipitation\":0},{\"dt\":1687803780,\"precipitation\":0},{\"dt\":1687803840,\"precipitation\":0},{\"dt\":1687803900,\"precipitation\":0},{\"dt\":1687803960,\"precipitation\":0},{\"dt\":1687804020,\"precipitation\":0},{\"dt\":1687804080,\"precipitation\":0},{\"dt\":1687804140,\"precipitation\":0}],\"hourly\":[{\"dt\":1687798800,\"temp\":22.01,\"feels_like\":21.44,\"pressure\":1020,\"humidity\":45,\"dew_point\":9.54,\"uvi\":0.93,\"clouds\":0,\"visibility\":10000,\"wind_speed\":5.33,\"wind_deg\":287,\"wind_gust\":7.12,\"weather\":[{\"id\":800,\"main\":\"Clear\",\"description\":\"clear sky\",\"icon\":\"01d\"}],\"pop\":0},{\"dt\":1687802400,\"temp\":21.65,\"feels_like\":21.07,\"pressure\":1020,\"humidity\":46,\"dew_point\":9.54,\"uvi\":0.41,\"clouds\":20,\"visibility\":10000,\"wind_speed\":5.14,\"wind_deg\":277,\"wind_gust\":6.12,\"weather\":[{\"id\":801,\"main\":\"Clouds\",\"description\":\"few clouds\",\"icon\":\"02d\"}],\"pop\":0},{\"dt\":1687806000,\"temp\":20.82,\"feels_like\":20.26,\"pressure\":1020,\"humidity\":50,\"dew_point\":10.03,\"uvi\":0.18,\"clouds\":40,\"visibility\":10000,\"wind_speed\":4.5,\"wind_deg\":273,\"wind_gust\":6.07,\"weather\":[{\"id\":802,\"main\":\"Clouds\",\"description\":\"scattered clouds\",\"icon\":\"03d\"}],\"pop\":0},{\"dt\":1687809600,\"temp\":19.69,\"feels_like\":19.12,\"pressure\":1021,\"humidity\":54,\"dew_point\":10.13,\"uvi\":0,\"clouds\":60,\"visibility\":10000,\"wind_speed\":3.86,\"wind_deg\":273,\"wind_gust\":6.28,\"weather\":[{\"id\":803,\"main\":\"Clouds\",\"description\":\"broken clouds\",\"icon\":\"04d\"}],\"pop\":0},{\"dt\":1687813200,\"temp\":18.08,\"feels_like\":17.48,\"pressure\":1022,\"humidity\":59,\"dew_point\":9.95,\"uvi\":0,\"clouds\":80,\"visibility\":10000,\"wind_speed\":3.52,\"wind_deg\":274,\"wind_gust\":7.2,\"weather\":[{\"id\":803,\"main\":\"Clouds\",\"description\":\"broken clouds\",\"icon\":\"04n\"}],\"pop\":0},{\"dt\":1687816800,\"temp\":16.35,\"feels_like\":15.76,\"pressure\":1022,\"humidity\":66,\"dew_point\":9.73,\"uvi\":0,\"clouds\":100,\"visibility\":10000,\"wind_speed\":3.11,\"wind_deg\":272,\"wind_gust\":7.24,\"weather\":[{\"id\":804,\"main\":\"Clouds\",\"description\":\"overcast clouds\",\"icon\":\"04n\"}],\"pop\":0},{\"dt\":1687820400,\"temp\":15.67,\"feels_like\":15.09,\"pressure\":1022,\"humidity\":69,\"dew_point\":9.93,\"uvi\":0,\"clouds\":100,\"visibility\":10000,\"wind_speed\":3.08,\"wind_deg\":273,\"wind_gust\":7.53,\"weather\":[{\"id\":804,\"main\":\"Clouds\",\"description\":\"overcast clouds\",\"icon\":\"04n\"}],\"pop\":0},{\"dt\":1687824000,\"temp\":15.01,\"feels_like\":14.47,\"pressure\":1022,\"humidity\":73,\"dew_point\":9.99,\"uvi\":0,\"clouds\":100,\"visibility\":10000,\"wind_speed\":2.72,\"wind_deg\":273,\"wind_gust\":6.97,\"weather\":[{\"id\":804,\"main\":\"Clouds\",\"description\":\"overcast clouds\",\"icon\":\"04n\"}],\"pop\":0},{\"dt\":1687827600,\"temp\":14.56,\"feels_like\":14.03,\"pressure\":1022,\"humidity\":75,\"dew_point\":10.1,\"uvi\":0,\"clouds\":100,\"visibility\":10000,\"wind_speed\":2.54,\"wind_deg\":267,\"wind_gust\":6.48,\"weather\":[{\"id\":804,\"main\":\"Clouds\",\"description\":\"overcast clouds\",\"icon\":\"04n\"}],\"pop\":0},{\"dt\":1687831200,\"temp\":14.16,\"feels_like\":13.64,\"pressure\":1022,\"humidity\":77,\"dew_point\":10.1,\"uvi\":0,\"clouds\":100,\"visibility\":10000,\"wind_speed\":2.47,\"wind_deg\":257,\"wind_gust\":5.76,\"weather\":[{\"id\":804,\"main\":\"Clouds\",\"description\":\"overcast clouds\",\"icon\":\"04n\"}],\"pop\":0},{\"dt\":1687834800,\"temp\":13.96,\"feels_like\":13.45,\"pressure\":1022,\"humidity\":78,\"dew_point\":10.1,\"uvi\":0,\"clouds\":100,\"visibility\":10000,\"wind_speed\":2.32,\"wind_deg\":260,\"wind_gust\":5.02,\"weather\":[{\"id\":804,\"main\":\"Clouds\",\"description\":\"overcast clouds\",\"icon\":\"04n\"}],\"pop\":0},{\"dt\":1687838400,\"temp\":13.56,\"feels_like\":13.06,\"pressure\":1022,\"humidity\":80,\"dew_point\":10.09,\"uvi\":0,\"clouds\":100,\"visibility\":10000,\"wind_speed\":2.13,\"wind_deg\":249,\"wind_gust\":5.29,\"weather\":[{\"id\":804,\"main\":\"Clouds\",\"description\":\"overcast clouds\",\"icon\":\"04d\"}],\"pop\":0},{\"dt\":1687842000,\"temp\":13.82,\"feels_like\":13.32,\"pressure\":1022,\"humidity\":79,\"dew_point\":10.21,\"uvi\":0.2,\"clouds\":100,\"visibility\":10000,\"wind_speed\":2.53,\"wind_deg\":250,\"wind_gust\":5.15,\"weather\":[{\"id\":804,\"main\":\"Clouds\",\"description\":\"overcast clouds\",\"icon\":\"04d\"}],\"pop\":0},{\"dt\":1687845600,\"temp\":14.87,\"feels_like\":14.4,\"pressure\":1022,\"humidity\":76,\"dew_point\":10.55,\"uvi\":0.63,\"clouds\":100,\"visibility\":10000,\"wind_speed\":2.69,\"wind_deg\":250,\"wind_gust\":5.02,\"weather\":[{\"id\":804,\"main\":\"Clouds\",\"description\":\"overcast clouds\",\"icon\":\"04d\"}],\"pop\":0},{\"dt\":1687849200,\"temp\":16.37,\"feels_like\":15.86,\"pressure\":1022,\"humidity\":69,\"dew_point\":10.66,\"uvi\":1.24,\"clouds\":100,\"visibility\":10000,\"wind_speed\":2.83,\"wind_deg\":252,\"wind_gust\":5.19,\"weather\":[{\"id\":804,\"main\":\"Clouds\",\"description\":\"overcast clouds\",\"icon\":\"04d\"}],\"pop\":0},{\"dt\":1687852800,\"temp\":16.14,\"feels_like\":15.66,\"pressure\":1022,\"humidity\":71,\"dew_point\":10.75,\"uvi\":2.31,\"clouds\":100,\"visibility\":10000,\"wind_speed\":3.09,\"wind_deg\":245,\"wind_gust\":5.3,\"weather\":[{\"id\":804,\"main\":\"Clouds\",\"description\":\"overcast clouds\",\"icon\":\"04d\"}],\"pop\":0},{\"dt\":1687856400,\"temp\":16.19,\"feels_like\":15.72,\"pressure\":1022,\"humidity\":71,\"dew_point\":10.83,\"uvi\":3.64,\"clouds\":100,\"visibility\":10000,\"wind_speed\":2.82,\"wind_deg\":247,\"wind_gust\":5.5,\"weather\":[{\"id\":804,\"main\":\"Clouds\",\"description\":\"overcast clouds\",\"icon\":\"04d\"}],\"pop\":0},{\"dt\":1687860000,\"temp\":18.25,\"feels_like\":17.72,\"pressure\":1021,\"humidity\":61,\"dew_point\":10.42,\"uvi\":2.19,\"clouds\":100,\"visibility\":10000,\"wind_speed\":3.31,\"wind_deg\":254,\"wind_gust\":5.33,\"weather\":[{\"id\":804,\"main\":\"Clouds\",\"description\":\"overcast clouds\",\"icon\":\"04d\"}],\"pop\":0},{\"dt\":1687863600,\"temp\":20.51,\"feels_like\":19.95,\"pressure\":1021,\"humidity\":51,\"dew_point\":10.02,\"uvi\":2.61,\"clouds\":100,\"visibility\":10000,\"wind_speed\":4.26,\"wind_deg\":251,\"wind_gust\":5.83,\"weather\":[{\"id\":804,\"main\":\"Clouds\",\"description\":\"overcast clouds\",\"icon\":\"04d\"}],\"pop\":0},{\"dt\":1687867200,\"temp\":20.55,\"feels_like\":20.04,\"pressure\":1021,\"humidity\":53,\"dew_point\":10.56,\"uvi\":2.77,\"clouds\":100,\"visibility\":10000,\"wind_speed\":4.5,\"wind_deg\":257,\"wind_gust\":6.02,\"weather\":[{\"id\":804,\"main\":\"Clouds\",\"description\":\"overcast clouds\",\"icon\":\"04d\"}],\"pop\":0},{\"dt\":1687870800,\"temp\":19.95,\"feels_like\":19.44,\"pressure\":1020,\"humidity\":55,\"dew_point\":10.54,\"uvi\":2.64,\"clouds\":100,\"visibility\":10000,\"wind_speed\":4.17,\"wind_deg\":256,\"wind_gust\":5.86,\"weather\":[{\"id\":804,\"main\":\"Clouds\",\"description\":\"overcast clouds\",\"icon\":\"04d\"}],\"pop\":0},{\"dt\":1687874400,\"temp\":19.21,\"feels_like\":18.7,\"pressure\":1020,\"humidity\":58,\"dew_point\":10.6,\"uvi\":2.22,\"clouds\":100,\"visibility\":10000,\"wind_speed\":4.64,\"wind_deg\":253,\"wind_gust\":6.85,\"weather\":[{\"id\":804,\"main\":\"Clouds\",\"description\":\"overcast clouds\",\"icon\":\"04d\"}],\"pop\":0},{\"dt\":1687878000,\"temp\":20.5,\"feels_like\":20.12,\"pressure\":1019,\"humidity\":58,\"dew_point\":11.96,\"uvi\":1.65,\"clouds\":100,\"visibility\":10000,\"wind_speed\":3.62,\"wind_deg\":250,\"wind_gust\":7.09,\"weather\":[{\"id\":804,\"main\":\"Clouds\",\"description\":\"overcast clouds\",\"icon\":\"04d\"}],\"pop\":0},{\"dt\":1687881600,\"temp\":21.95,\"feels_like\":21.74,\"pressure\":1019,\"humidity\":59,\"dew_point\":13.37,\"uvi\":0.89,\"clouds\":99,\"visibility\":10000,\"wind_speed\":5.3,\"wind_deg\":266,\"wind_gust\":7.42,\"weather\":[{\"id\":804,\"main\":\"Clouds\",\"description\":\"overcast clouds\",\"icon\":\"04d\"}],\"pop\":0},{\"dt\":1687885200,\"temp\":21.17,\"feels_like\":20.96,\"pressure\":1018,\"humidity\":62,\"dew_point\":13.51,\"uvi\":0.48,\"clouds\":99,\"visibility\":10000,\"wind_speed\":4.68,\"wind_deg\":262,\"wind_gust\":7.49,\"weather\":[{\"id\":804,\"main\":\"Clouds\",\"description\":\"overcast clouds\",\"icon\":\"04d\"}],\"pop\":0},{\"dt\":1687888800,\"temp\":21.5,\"feels_like\":21.38,\"pressure\":1018,\"humidity\":64,\"dew_point\":14.18,\"uvi\":0.21,\"clouds\":98,\"visibility\":10000,\"wind_speed\":4.29,\"wind_deg\":261,\"wind_gust\":7.51,\"weather\":[{\"id\":804,\"main\":\"Clouds\",\"description\":\"overcast clouds\",\"icon\":\"04d\"}],\"pop\":0},{\"dt\":1687892400,\"temp\":20.82,\"feels_like\":20.76,\"pressure\":1018,\"humidity\":69,\"dew_point\":14.73,\"uvi\":0.05,\"clouds\":100,\"visibility\":10000,\"wind_speed\":3.6,\"wind_deg\":255,\"wind_gust\":6.87,\"weather\":[{\"id\":804,\"main\":\"Clouds\",\"description\":\"overcast clouds\",\"icon\":\"04d\"}],\"pop\":0},{\"dt\":1687896000,\"temp\":20,\"feels_like\":19.96,\"pressure\":1018,\"humidity\":73,\"dew_point\":14.83,\"uvi\":0,\"clouds\":99,\"visibility\":10000,\"wind_speed\":3.36,\"wind_deg\":256,\"wind_gust\":7.42,\"weather\":[{\"id\":804,\"main\":\"Clouds\",\"description\":\"overcast clouds\",\"icon\":\"04d\"}],\"pop\":0},{\"dt\":1687899600,\"temp\":18.8,\"feels_like\":18.8,\"pressure\":1019,\"humidity\":79,\"dew_point\":15.01,\"uvi\":0,\"clouds\":95,\"visibility\":10000,\"wind_speed\":3.22,\"wind_deg\":249,\"wind_gust\":7.81,\"weather\":[{\"id\":804,\"main\":\"Clouds\",\"description\":\"overcast clouds\",\"icon\":\"04n\"}],\"pop\":0},{\"dt\":1687903200,\"temp\":18.03,\"feels_like\":18.08,\"pressure\":1018,\"humidity\":84,\"dew_point\":15.1,\"uvi\":0,\"clouds\":85,\"visibility\":10000,\"wind_speed\":3.23,\"wind_deg\":249,\"wind_gust\":8.2,\"weather\":[{\"id\":804,\"main\":\"Clouds\",\"description\":\"overcast clouds\",\"icon\":\"04n\"}],\"pop\":0},{\"dt\":1687906800,\"temp\":17.54,\"feels_like\":17.62,\"pressure\":1018,\"humidity\":87,\"dew_point\":15.18,\"uvi\":0,\"clouds\":78,\"visibility\":10000,\"wind_speed\":3.36,\"wind_deg\":250,\"wind_gust\":8.57,\"weather\":[{\"id\":803,\"main\":\"Clouds\",\"description\":\"broken clouds\",\"icon\":\"04n\"}],\"pop\":0},{\"dt\":1687910400,\"temp\":17.05,\"feels_like\":17.13,\"pressure\":1018,\"humidity\":89,\"dew_point\":15.07,\"uvi\":0,\"clouds\":68,\"visibility\":10000,\"wind_speed\":3.31,\"wind_deg\":254,\"wind_gust\":8.45,\"weather\":[{\"id\":803,\"main\":\"Clouds\",\"description\":\"broken clouds\",\"icon\":\"04n\"}],\"pop\":0},{\"dt\":1687914000,\"temp\":16.73,\"feels_like\":16.81,\"pressure\":1018,\"humidity\":90,\"dew_point\":14.87,\"uvi\":0,\"clouds\":12,\"visibility\":10000,\"wind_speed\":3.05,\"wind_deg\":257,\"wind_gust\":8.44,\"weather\":[{\"id\":801,\"main\":\"Clouds\",\"description\":\"few clouds\",\"icon\":\"02n\"}],\"pop\":0},{\"dt\":1687917600,\"temp\":16.31,\"feels_like\":16.37,\"pressure\":1018,\"humidity\":91,\"dew_point\":14.78,\"uvi\":0,\"clouds\":13,\"visibility\":10000,\"wind_speed\":2.9,\"wind_deg\":263,\"wind_gust\":8.5,\"weather\":[{\"id\":801,\"main\":\"Clouds\",\"description\":\"few clouds\",\"icon\":\"02n\"}],\"pop\":0},{\"dt\":1687921200,\"temp\":16.07,\"feels_like\":16.16,\"pressure\":1017,\"humidity\":93,\"dew_point\":14.84,\"uvi\":0,\"clouds\":19,\"visibility\":10000,\"wind_speed\":2.74,\"wind_deg\":267,\"wind_gust\":8.18,\"weather\":[{\"id\":801,\"main\":\"Clouds\",\"description\":\"few clouds\",\"icon\":\"02n\"}],\"pop\":0},{\"dt\":1687924800,\"temp\":16.23,\"feels_like\":16.34,\"pressure\":1017,\"humidity\":93,\"dew_point\":14.88,\"uvi\":0,\"clouds\":25,\"visibility\":10000,\"wind_speed\":2.64,\"wind_deg\":265,\"wind_gust\":7.18,\"weather\":[{\"id\":802,\"main\":\"Clouds\",\"description\":\"scattered clouds\",\"icon\":\"03d\"}],\"pop\":0},{\"dt\":1687928400,\"temp\":17.51,\"feels_like\":17.43,\"pressure\":1018,\"humidity\":81,\"dew_point\":14.2,\"uvi\":0.12,\"clouds\":38,\"visibility\":10000,\"wind_speed\":3.07,\"wind_deg\":270,\"wind_gust\":6.2,\"weather\":[{\"id\":802,\"main\":\"Clouds\",\"description\":\"scattered clouds\",\"icon\":\"03d\"}],\"pop\":0},{\"dt\":1687932000,\"temp\":18.29,\"feels_like\":18.16,\"pressure\":1018,\"humidity\":76,\"dew_point\":13.74,\"uvi\":0.38,\"clouds\":48,\"visibility\":10000,\"wind_speed\":3,\"wind_deg\":264,\"wind_gust\":5.21,\"weather\":[{\"id\":802,\"main\":\"Clouds\",\"description\":\"scattered clouds\",\"icon\":\"03d\"}],\"pop\":0},{\"dt\":1687935600,\"temp\":19.26,\"feels_like\":19.1,\"pressure\":1018,\"humidity\":71,\"dew_point\":13.85,\"uvi\":0.62,\"clouds\":97,\"visibility\":10000,\"wind_speed\":2.94,\"wind_deg\":261,\"wind_gust\":4.33,\"weather\":[{\"id\":804,\"main\":\"Clouds\",\"description\":\"overcast clouds\",\"icon\":\"04d\"}],\"pop\":0},{\"dt\":1687939200,\"temp\":20.49,\"feels_like\":20.32,\"pressure\":1017,\"humidity\":66,\"dew_point\":13.91,\"uvi\":1.16,\"clouds\":96,\"visibility\":10000,\"wind_speed\":2.91,\"wind_deg\":259,\"wind_gust\":3.92,\"weather\":[{\"id\":804,\"main\":\"Clouds\",\"description\":\"overcast clouds\",\"icon\":\"04d\"}],\"pop\":0},{\"dt\":1687942800,\"temp\":21.88,\"feels_like\":21.74,\"pressure\":1017,\"humidity\":62,\"dew_point\":14.21,\"uvi\":1.83,\"clouds\":96,\"visibility\":10000,\"wind_speed\":3.07,\"wind_deg\":258,\"wind_gust\":3.92,\"weather\":[{\"id\":804,\"main\":\"Clouds\",\"description\":\"overcast clouds\",\"icon\":\"04d\"}],\"pop\":0},{\"dt\":1687946400,\"temp\":23.02,\"feels_like\":22.89,\"pressure\":1017,\"humidity\":58,\"dew_point\":14.29,\"uvi\":3.84,\"clouds\":93,\"visibility\":10000,\"wind_speed\":3.25,\"wind_deg\":250,\"wind_gust\":3.83,\"weather\":[{\"id\":804,\"main\":\"Clouds\",\"description\":\"overcast clouds\",\"icon\":\"04d\"}],\"pop\":0},{\"dt\":1687950000,\"temp\":23.51,\"feels_like\":23.38,\"pressure\":1017,\"humidity\":56,\"dew_point\":14.23,\"uvi\":4.59,\"clouds\":91,\"visibility\":10000,\"wind_speed\":3.7,\"wind_deg\":247,\"wind_gust\":4.25,\"weather\":[{\"id\":804,\"main\":\"Clouds\",\"description\":\"overcast clouds\",\"icon\":\"04d\"}],\"pop\":0},{\"dt\":1687953600,\"temp\":23.3,\"feels_like\":23.17,\"pressure\":1017,\"humidity\":57,\"dew_point\":14.24,\"uvi\":4.87,\"clouds\":93,\"visibility\":10000,\"wind_speed\":3.96,\"wind_deg\":254,\"wind_gust\":4.55,\"weather\":[{\"id\":804,\"main\":\"Clouds\",\"description\":\"overcast clouds\",\"icon\":\"04d\"}],\"pop\":0},{\"dt\":1687957200,\"temp\":23.4,\"feels_like\":23.28,\"pressure\":1017,\"humidity\":57,\"dew_point\":14.2,\"uvi\":4.31,\"clouds\":100,\"visibility\":10000,\"wind_speed\":3.88,\"wind_deg\":258,\"wind_gust\":4.66,\"weather\":[{\"id\":804,\"main\":\"Clouds\",\"description\":\"overcast clouds\",\"icon\":\"04d\"}],\"pop\":0},{\"dt\":1687960800,\"temp\":24.16,\"feels_like\":24.04,\"pressure\":1016,\"humidity\":54,\"dew_point\":14.15,\"uvi\":3.64,\"clouds\":100,\"visibility\":10000,\"wind_speed\":3.95,\"wind_deg\":263,\"wind_gust\":4.64,\"weather\":[{\"id\":804,\"main\":\"Clouds\",\"description\":\"overcast clouds\",\"icon\":\"04d\"}],\"pop\":0},{\"dt\":1687964400,\"temp\":24.17,\"feels_like\":24.05,\"pressure\":1016,\"humidity\":54,\"dew_point\":14.13,\"uvi\":2.7,\"clouds\":100,\"visibility\":10000,\"wind_speed\":4.18,\"wind_deg\":269,\"wind_gust\":4.82,\"weather\":[{\"id\":804,\"main\":\"Clouds\",\"description\":\"overcast clouds\",\"icon\":\"04d\"}],\"pop\":0},{\"dt\":1687968000,\"temp\":24.61,\"feels_like\":24.48,\"pressure\":1016,\"humidity\":52,\"dew_point\":13.91,\"uvi\":1.56,\"clouds\":100,\"visibility\":10000,\"wind_speed\":4.11,\"wind_deg\":272,\"wind_gust\":4.74,\"weather\":[{\"id\":804,\"main\":\"Clouds\",\"description\":\"overcast clouds\",\"icon\":\"04d\"}],\"pop\":0.05}],\"daily\":[{\"dt\":1687780800,\"sunrise\":1687751111,\"sunset\":1687810942,\"moonrise\":1687781760,\"moonset\":1687737720,\"moon_phase\":0.25,\"temp\":{\"day\":22.27,\"min\":13.97,\"max\":22.33,\"night\":16.35,\"eve\":21.65,\"morn\":15.45},\"feels_like\":{\"day\":21.47,\"night\":15.76,\"eve\":21.07,\"morn\":14.96},\"pressure\":1020,\"humidity\":35,\"dew_point\":6.02,\"wind_speed\":5.71,\"wind_deg\":282,\"wind_gust\":10.89,\"weather\":[{\"id\":803,\"main\":\"Clouds\",\"description\":\"broken clouds\",\"icon\":\"04d\"}],\"clouds\":66,\"pop\":0,\"uvi\":6.92},{\"dt\":1687867200,\"sunrise\":1687837538,\"sunset\":1687897338,\"moonrise\":1687872540,\"moonset\":1687824780,\"moon_phase\":0.29,\"temp\":{\"day\":20.55,\"min\":13.56,\"max\":21.95,\"night\":18.03,\"eve\":21.5,\"morn\":14.87},\"feels_like\":{\"day\":20.04,\"night\":18.08,\"eve\":21.38,\"morn\":14.4},\"pressure\":1021,\"humidity\":53,\"dew_point\":10.56,\"wind_speed\":5.3,\"wind_deg\":266,\"wind_gust\":8.2,\"weather\":[{\"id\":804,\"main\":\"Clouds\",\"description\":\"overcast clouds\",\"icon\":\"04d\"}],\"clouds\":100,\"pop\":0,\"uvi\":3.64},{\"dt\":1687953600,\"sunrise\":1687923968,\"sunset\":1687983732,\"moonrise\":1687963560,\"moonset\":1687911900,\"moon_phase\":0.32,\"temp\":{\"day\":23.3,\"min\":16.07,\"max\":24.61,\"night\":20.12,\"eve\":23.07,\"morn\":18.29},\"feels_like\":{\"day\":23.17,\"night\":20.28,\"eve\":22.95,\"morn\":18.16},\"pressure\":1017,\"humidity\":57,\"dew_point\":14.24,\"wind_speed\":4.31,\"wind_deg\":275,\"wind_gust\":8.57,\"weather\":[{\"id\":804,\"main\":\"Clouds\",\"description\":\"overcast clouds\",\"icon\":\"04d\"}],\"clouds\":93,\"pop\":0.16,\"uvi\":4.87},{\"dt\":1688040000,\"sunrise\":1688010400,\"sunset\":1688070122,\"moonrise\":1688054760,\"moonset\":1687999140,\"moon_phase\":0.35,\"temp\":{\"day\":14.94,\"min\":14.65,\"max\":19.89,\"night\":14.96,\"eve\":18.15,\"morn\":15.12},\"feels_like\":{\"day\":14.5,\"night\":14.68,\"eve\":17.61,\"morn\":15.12},\"pressure\":1019,\"humidity\":77,\"dew_point\":10.66,\"wind_speed\":3.75,\"wind_deg\":346,\"wind_gust\":7.15,\"weather\":[{\"id\":501,\"main\":\"Rain\",\"description\":\"moderate rain\",\"icon\":\"10d\"}],\"clouds\":100,\"pop\":1,\"rain\":9.71,\"uvi\":2.83},{\"dt\":1688126400,\"sunrise\":1688096835,\"sunset\":1688156509,\"moonrise\":1688146260,\"moonset\":1688086560,\"moon_phase\":0.39,\"temp\":{\"day\":21.78,\"min\":12.38,\"max\":21.78,\"night\":16.23,\"eve\":17.39,\"morn\":13.99},\"feels_like\":{\"day\":21.01,\"night\":15.87,\"eve\":16.86,\"morn\":13.14},\"pressure\":1013,\"humidity\":38,\"dew_point\":6.82,\"wind_speed\":3.94,\"wind_deg\":254,\"wind_gust\":7.33,\"weather\":[{\"id\":500,\"main\":\"Rain\",\"description\":\"light rain\",\"icon\":\"10d\"}],\"clouds\":76,\"pop\":0.38,\"rain\":0.51,\"uvi\":7.2},{\"dt\":1688212800,\"sunrise\":1688183273,\"sunset\":1688242894,\"moonrise\":1688237820,\"moonset\":1688174520,\"moon_phase\":0.42,\"temp\":{\"day\":17.95,\"min\":15.23,\"max\":21.16,\"night\":17.71,\"eve\":19.3,\"morn\":15.77},\"feels_like\":{\"day\":17.76,\"night\":17.34,\"eve\":18.83,\"morn\":15.73},\"pressure\":1007,\"humidity\":75,\"dew_point\":13.41,\"wind_speed\":6.22,\"wind_deg\":283,\"wind_gust\":8.89,\"weather\":[{\"id\":500,\"main\":\"Rain\",\"description\":\"light rain\",\"icon\":\"10d\"}],\"clouds\":91,\"pop\":0.51,\"rain\":0.56,\"uvi\":8},{\"dt\":1688299200,\"sunrise\":1688269714,\"sunset\":1688329275,\"moonrise\":1688328840,\"moonset\":1688263200,\"moon_phase\":0.46,\"temp\":{\"day\":21.08,\"min\":13.48,\"max\":22.02,\"night\":16.48,\"eve\":20.46,\"morn\":13.48},\"feels_like\":{\"day\":20.29,\"night\":15.78,\"eve\":19.74,\"morn\":12.79},\"pressure\":1013,\"humidity\":40,\"dew_point\":6.88,\"wind_speed\":5.41,\"wind_deg\":284,\"wind_gust\":9.8,\"weather\":[{\"id\":500,\"main\":\"Rain\",\"description\":\"light rain\",\"icon\":\"10d\"}],\"clouds\":2,\"pop\":0.2,\"rain\":0.13,\"uvi\":8},{\"dt\":1688385600,\"sunrise\":1688356157,\"sunset\":1688415653,\"moonrise\":1688418840,\"moonset\":1688353020,\"moon_phase\":0.5,\"temp\":{\"day\":18.03,\"min\":13.44,\"max\":22.28,\"night\":15.51,\"eve\":19.97,\"morn\":13.44},\"feels_like\":{\"day\":18.06,\"night\":14.74,\"eve\":19.22,\"morn\":12.93},\"pressure\":1006,\"humidity\":83,\"dew_point\":15,\"wind_speed\":7.66,\"wind_deg\":259,\"wind_gust\":13.13,\"weather\":[{\"id\":500,\"main\":\"Rain\",\"description\":\"light rain\",\"icon\":\"10d\"}],\"clouds\":100,\"pop\":1,\"rain\":3.18,\"uvi\":8}]}","payloadType":"json","x":570,"y":4920,"wires":[["fddda58d47a6f382"]]},{"id":"346cbf054655cf12","type":"ui_chart","z":"b9860b4b9de8c8da","name":"","group":"de62ed6.ddb1e1","order":3,"width":"6","height":"3","label":"Rain - Next Hour","chartType":"line","legend":"false","xformat":"auto","interpolate":"step","nodata":"Errr - no data yet!","dot":false,"ymin":"","ymax":"","removeOlder":"24","removeOlderPoints":"","removeOlderUnit":"3600","cutout":0,"useOneColor":true,"useUTC":false,"colors":["#1f77b4","#aec7e8","#ff7f0e","#2ca02c","#98df8a","#d62728","#ff9896","#9467bd","#c5b0d5"],"outputs":1,"useDifferentColor":false,"className":"","x":730,"y":4860,"wires":[[]]},{"id":"3f4fda4b63dd90c7","type":"debug","z":"b9860b4b9de8c8da","name":"debug 316","active":true,"tosidebar":true,"console":false,"tostatus":false,"complete":"false","statusVal":"","statusType":"auto","x":650,"y":4800,"wires":[]},{"id":"de62ed6.ddb1e1","type":"ui_group","name":"Status","tab":"8cd9325b.caa1a","order":1,"disp":false,"width":"6","collapse":false,"className":""},{"id":"8cd9325b.caa1a","type":"ui_tab","name":"Living Room","icon":"dashboard","order":1,"disabled":false,"hidden":false}]
Uses msg.ui_controla and Elements | Chart.js
If you read the chartjs docs, you may be able to change the bar chart labels, not tried myself though.
