Problem after upgrading Node-RED to 1.0.1
.. just updated a freshly installed Raspberry Pi with Buster to the latest version of Node-RED as described under https://nodered.org/docs/getting-started/raspberrypi ..
Is there any reason why nodes installed via "manage palette" like Eztimer or Bigtimer are not available ?
Thanks ..
Can you explain in more detail what you mean?
I just tried installing Eztimer on my Pi4 using 1.0.1 using the palette and it installed fine
(I already had Bigtimer installed)
