Python, MQTT, display colored lines in one widget
For my Node-Red waste calendar, the following lines are generated via Python and MQTT
pass to Node-Red:
Publishing to MQTT topic: Home/RPi44/Abfall_1
Message: Tue 08.02.2022 yellow recycling bin
Publishing to MQTT topic: Home/RPi44/Abfall_2
Message: Wed 09.02.2022 black residual waste bin
Publishing to MQTT topic: Home/RPi44/Abfall_3
Message: Wed 02/16/2022 black residual waste bin
Publishing to MQTT topic: Home/RPi44/Abfall_4
Message: Wed 02/16/2022 blue paper bin
Node-Red then produces colored output
grafik
In order to be able to accommodate more rows, I want to display all rows in one widget.
Di 08.02.2022 gelbe Wertstofftonne
Mi 09.02.2022 schwarze Restmülltonne
Mi 16.02.2022 schwarze Restmülltonne
Mi 16.02.2022 blaue Papiertonne
flows.json (30.9 KB)
I have found that a long string is possible for me
, but then how do I adjust the colors.
Please help.
I imported your flow but cannot really test it.
Could you provide a screen shot how it looks now, and perhaps some test data for setup via inject nodes rather than MQTT.
You could use a template node to display the info, as then you will have more control over the colors etc.
I've added 4 injects for different colors. In addition, an inject with
that shows how it should look, but still without colors. I can't do anything with templatets yet, maybe I'll get some help or a tip for the existing output as well can be done with a widget.
Kalender.json (30.0 KB)
Your flow seems unnecessarily complicated.
You have 4 copies of this block of nodes. Are they identical, apart from msg.topic?
What is the purpose of having the split node connected to the join node?
If you have Handle as a stream of messages checked, nothing will come from the split
If you have it unchecked, the results will be the same as what went into the split node.
grafik
I copied almost everything from somewhere. I removed the splits and joins and the display works as before.
From my RPi I always get the next 4 appointments via Python and MQTT, which I don't want to display in 4 widgets, but in one.
Kalende1.json (25.9 KB)
do you get 4 different messages or just 1 ?
can you provide exactly what you get from the mqtt input please ?
I get 4 differen messages, the next 4 days.
16.03.2022 blaue Papiertonne
Tho collur, date and 'Tonne' are differnt.
so do you get 1 message for each color, from 4 different topics ?
Looking at your first post there are 4 mqtt inputs.
So is topic Abfall_1 allways for the same color bin ? If so then the topic could tell us the color ?
You didn't answer my question so it's possible that this won't answer yours, but perhaps worth trying.
Untitled 5
[{"id":"6d42f030bd923829","type":"tab","label":"Abfallkalender","disabled":false,"info":""},{"id":"0fab64809f592209","type":"inject","z":"6d42f030bd923829","name":"","props":[{"p":"payload"},{"p":"topic","vt":"str"}],"repeat":"","crontab":"","once":false,"onceDelay":0.1,"topic":"Home/RPi44/Abfall_1","payload":"16.03.2022 blaue Papiertonne","payloadType":"str","x":170,"y":100,"wires":[["d3ddbe358ae2c911"]]},{"id":"19883144e42c386c","type":"inject","z":"6d42f030bd923829","name":"","props":[{"p":"payload"},{"p":"topic","vt":"str"}],"repeat":"","crontab":"","once":false,"onceDelay":0.1,"topic":"Home/RPi44/Abfall_2","payload":"18.03.2022 grüne Biotonne","payloadType":"str","x":170,"y":140,"wires":[["d3ddbe358ae2c911"]]},{"id":"0ff9beda1abfba01","type":"inject","z":"6d42f030bd923829","name":"","props":[{"p":"payload"},{"p":"topic","vt":"str"}],"repeat":"","crontab":"","once":false,"onceDelay":0.1,"topic":"Home/RPi44/Abfall_3","payload":"22.03.2022 gelbe  Wertstofftonne","payloadType":"str","x":170,"y":180,"wires":[["d3ddbe358ae2c911"]]},{"id":"efc8437ce7cfb0e4","type":"inject","z":"6d42f030bd923829","name":"","props":[{"p":"payload"},{"p":"topic","vt":"str"}],"repeat":"","crontab":"","once":false,"onceDelay":0.1,"topic":"Home/RPi44/Abfall_4","payload":" 23.03.2022 schwarze Restmülltonne","payloadType":"str","x":170,"y":220,"wires":[["d3ddbe358ae2c911"]]},{"id":"d3ddbe358ae2c911","type":"join","z":"6d42f030bd923829","name":"","mode":"custom","build":"object","property":"payload","propertyType":"msg","key":"topic","joiner":"\\n","joinerType":"str","accumulate":true,"timeout":"","count":"1","reduceRight":false,"reduceExp":"","reduceInit":"","reduceInitType":"","reduceFixup":"","x":370,"y":120,"wires":[["fc65bded99e44615"]]},{"id":"437988dad5e380d9","type":"ui_template","z":"6d42f030bd923829","group":"0b2c5ed94dd5b6dc","name":"","order":6,"width":"7","height":"4","format":"<style>\n    td.black { color: black; }\n    td.blue { color: blue; }\n    td.green { color: green; }\n    td.orange { color: orange; }\n</style>\n\n<table class=\"table\">\n    <tr ng-repeat=\"line in msg.payload\">\n        <td class =\"{{line.class}}\">{{line.text}}</td>\n    </tr>\n</table>\n\n","storeOutMessages":true,"fwdInMessages":true,"resendOnRefresh":true,"templateScope":"local","className":"","x":680,"y":120,"wires":[[]]},{"id":"fc65bded99e44615","type":"function","z":"6d42f030bd923829","name":"","func":"let data = msg.payload;\nvar out = [];\nout.push();\nlet foo = {};\n    \nconst keys = Object.keys(data);\n\nkeys.forEach((key, index) => {\n    let myvar = data[key];\n    let myclass = \"none\";\n    if (myvar.includes(\"schwarz\")) {myclass = \"black\"}\n    if (myvar.includes(\"grüne\")) {myclass = \"green\"}\n    if (myvar.includes(\"gelb\")) {myclass = \"orange\"}\n    if (myvar.includes(\"blau\")) {myclass = \"blue\"}\n    \n    out.push(  {class: myclass, text: myvar } )\n\n//    msg.payload.key.class = \"foo\";\n});\n\nmsg.payload = out;\nreturn msg;","outputs":1,"noerr":0,"initialize":"","finalize":"","libs":[],"x":520,"y":120,"wires":[["437988dad5e380d9"]]},{"id":"9903092624fc44d4","type":"mqtt in","z":"6d42f030bd923829","name":"","topic":"Home/RPi44/#","qos":"2","datatype":"utf8","broker":"3dd428715c0663e1","nl":false,"rap":false,"inputs":0,"x":140,"y":60,"wires":[["d3ddbe358ae2c911"]]},{"id":"b69c31d9a2fa9385","type":"ui_spacer","z":"6d42f030bd923829","name":"spacer","group":"777e77b5cf0d244e","order":3,"width":1,"height":1},{"id":"89b93ed723fc9b6b","type":"ui_spacer","z":"6d42f030bd923829","name":"spacer","group":"777e77b5cf0d244e","order":7,"width":1,"height":1},{"id":"deec755f09e8585b","type":"ui_spacer","z":"6d42f030bd923829","name":"spacer","group":"777e77b5cf0d244e","order":8,"width":1,"height":1},{"id":"51486b43087fd20e","type":"ui_spacer","z":"6d42f030bd923829","name":"spacer","group":"777e77b5cf0d244e","order":11,"width":1,"height":1},{"id":"fbbc029b2db14b80","type":"ui_spacer","z":"6d42f030bd923829","name":"spacer","group":"e9da5156132bafb5","order":3,"width":2,"height":1},{"id":"67966b508bc7016d","type":"ui_spacer","z":"6d42f030bd923829","name":"spacer","group":"e9da5156132bafb5","order":5,"width":2,"height":1},{"id":"41eff89a215ef5be","type":"ui_spacer","z":"6d42f030bd923829","name":"spacer","group":"e9da5156132bafb5","order":7,"width":2,"height":1},{"id":"2b35ccb741ad9f47","type":"ui_spacer","z":"6d42f030bd923829","name":"spacer","group":"e9da5156132bafb5","order":9,"width":2,"height":1},{"id":"0b2c5ed94dd5b6dc","type":"ui_group","name":"Demo","tab":"4311353dbffb7643","order":1,"disp":true,"width":"10","collapse":false,"className":""},{"id":"3dd428715c0663e1","type":"mqtt-broker","name":"RPi44","broker":"192.168.178.44","port":"1883","clientid":"","autoConnect":true,"usetls":false,"protocolVersion":"4","keepalive":"60","cleansession":true,"birthTopic":"/sonoff-light","birthQos":"0","birthRetain":"false","birthPayload":"/sonoff-light","birthMsg":{},"closeTopic":"","closeQos":"0","closeRetain":"false","closePayload":"","closeMsg":{},"willTopic":"","willQos":"0","willRetain":"false","willPayload":"","willMsg":{},"sessionExpiry":""},{"id":"777e77b5cf0d244e","type":"ui_group","name":"Hamburg Wetter ","tab":"4bb34f67.69a87","order":1,"disp":false,"width":10,"collapse":false},{"id":"e9da5156132bafb5","type":"ui_group","name":"AbfallKalender","tab":"4bb34f67.69a87","order":3,"disp":false,"width":10,"collapse":false},{"id":"4311353dbffb7643","type":"ui_tab","name":"Demo","icon":"dashboard","disabled":false,"hidden":false},{"id":"4bb34f67.69a87","type":"ui_tab","name":"Hamburg Wetter, Benzinpreise Wellingsbüttel, Abfallkalender","icon":"fa-thermometer-half","order":1,"disabled":false,"hidden":false}]
@jbudd Beat me to it - I was just trying to tease out a bit more info :wink:
I'll let him explain how it works then :rofl:
Well I'd be interested to see your answer smcgann99 because I had a devil of a job working out how to convert the inputs to an object and the object to an array of objects!
Wait - explain how it works??
Isn't it obvious? :wink:
We need some kind of ticket allocation, I keep getting gazumped :wink:
Hopefully this explains my approach:
  1. The MQTT in node gets all topics not just one.
  2. The Join combines them into a single object containing something like
{"Home/RPi44/Abfall_1":"16.03.2022 blaue Papiertonne",
"Home/RPi44/Abfall_2":"18.03.2022 grüne Biotonne",
"Home/RPi44/Abfall_3":"22.03.2022 gelbe Wertstofftonne"}
3 Function node annotated (and stripped of some crud):
let data = msg.payload;     //Make a local copy
var out = [];               //An array for the result because the ui-template table expecht an array
const keys = Object.keys(data);  // The list of elements in the input data
keys.forEach((key, index) => {   // Loop though the input data object
    let myvar = data[key];      // A local copy of just the current element
    let myclass = "none";       // Add a field "class" which will be used to style the table row
    if (myvar.includes("schwarz")) {myclass = "black"}
    if (myvar.includes("grüne")) {myclass = "green"}
    if (myvar.includes("gelb")) {myclass = "orange"}
    if (myvar.includes("blau")) {myclass = "blue"}
    out.push(  {class: myclass, text: myvar } )   // Push it to the array, discarding the "Home/RPi44/ABfall.." stuff as it's no longer needed
msg.payload = out;
4 The template node contains some CSS classes for black, blue, orange and green. It assembles the table rows from the array it receives.
grafik
I'm thrilled and have to play with the template a bit tomorrow, hopefully understand it too
Many thanks!
