Queue of the group position of a widget
Since a short time I have problems with the queue of the group position of a widget. The last added group is at the end of the queue and the rest is unsorted. Is there a way to see the queue in a sequence as seen in the Tab and Links tab of the dashboard Layout ; as it was?
I think it happened after updating node red and the imported nodes, but I am not sure about this.
I think there have been a few issues with this code, it is rather complex. Are you using the latest version of node-red-dashboard? If not then upgrade it. If you are, or that does not fix it, then move one or two of the older groups about and see if it sorts itself out.
