RaspberryPi OS Bullseye and xrdp not working
I am trying to set up a new Raspi with Bullseye. Unfortunately xrdp is not working. Does anybody have the same problem and eventually a solution?
In what way does this have anything to do with Node-RED?
yes, it has to do something with node-red as I am editing my node-red flows using my Windows PC and xrdp. I suppose, that I am not the only one doing it this way.
no, but then, there is no need to do that. You can simply access the remote node-red via a browser...
http://<ip-of-node-red-server>:1880
you are right!
What I meant is installing and update node-red and editing node-red related files. This is much easier with xrdp than with a direct connection to the Raspi. Especially with 10 Raspi which I want to manage.
I have had mixed results with xrdp over the years and tend to just use VNC.
Is VNC not an option?
If not, then I suggest you have a look at raspberry pi forums - they will likely know the reason or be better equipped to help.
Personally, i just use SSH (terminal) and mc for those times when I cant remember how to chmod or want to edit a file.
WindowsTerminal_hhRvalR3xS
That looks very good. I will give it a try.
No, it is a raspberry pi config and apps question.
Node-RED has a web-based Editor and doesn't require remote desktop access. Running remote desktop on most Pi's slows them to a crawl when used along side a healthy set of services.
I guess I solved that - you need to create an additional user to get an RDP session - now it works fine for me. :wink: You cannot use pi - as this user probably is already logged on, on your raspberry desktop.
However I use the Webinterface to edit my NodeRed flows - is much faster as on the Raspberry. :wink:
If you create a new user, you have to add the new user-id in the sudoers etc .to have the same rights as the pi user.
looks very good!
I am not very familiar with unix.
Which commands do I need to add a new user with the same rights as pi?
PS: I of course use google chrome on my PC to edit my flows. I was putting it wrong in my former post.
I am also not a power user in unix, so I had to Google as well.
But I think, you can google as well. So addusers and a user to sudoers or looking to which groups pi and add the new user to the same groups should be possible. I managed that - and I am sure you will be able to do this as well.
I successfully got access to my Raspi with xrdp useing a different user! Many thanks for the tip
Still have to find a way to add it to sudoers.
This link should possibly help.
Great Web-Site: Raspi Support
I totally forgot MC. Great tool.
Many thanks for the tip.
did you install it?
It is my go-to LONG before RDP/VNC.
yes I did. Like it. Very helpfull!
I used it long time ago and then forgot it :wink:
this helped me with xrdp! :+1: :slight_smile:
