Giamma
19 September 2022 16:16
1
on my Raspberry Pi4 (so raspberry standard) I have a directory shared with smb.
I'd like to read from my pc with ubuntu the file TemperatureData.log but I cannot set correctly the smb node ....
configuration node smb 01
configuration node smb 02
error
Can you help me?
I also have an httpStatic on my Raspberry and I could move the file into this directory if it helps ....
If there is another solution to read the file that's fine too ...
Rather than trying to access an SMB: URI, use Raspbian to mount the folder and then it will just look like any other folder on the device.
Giamma
20 September 2022 04:32
3
Ok, I succeeded and now works fine. Thank you ...
This is the instruction to mount Raspberry smb shared folder in ubuntu:
sudo mount -t cifs -o vers=3.0,username=[insert_username],password=[insert_pwd] //192.168.1.28/[name_folder_raspberry] /[path_destination_folder_ubuntu]
