I wish to use the "node-red-contrib-bacnet". In order to test it, I use a BacnNet simulator (The simulator is Room Controller Simulator and the BacNet explorer is Yabe).
For example, I would like to read the temperature value (21°C) shown below:
I set up my node like this:
If I only send a timestamp, it returns the value "17". This is the value that is contained in the PRESENT_VALUE of an object that I'm not selected. I don't know why I receive back this value.
If on the other hand I send the information about the object I want to read to the bacnet node(see image below), I get the error below :
However, the data I'm sending corresponds to what is described in the Node documentation.
How do I get to read the PRESENT_VALUE of the objectID: OBJECT_ANALOG_INPUT:0 with Node-RED? Have any of you experienced this problem before?
Thank you for your help.
