Redirecting to dashboard from flow
Is there a way i redirect to dashboard from the flow.
I get HTML as msg.payload and this i could send to dashboard, but user has to click on dashboard icon to preview it. How do i redirect to dashboard from the flow, say it opens in a new tab when the flow runs ?
Note: Node red instance is on a different machine(m2) and i access this from my machine(m1) - which means from my machine i open m2's node red url and have to redirect to dashboard(m2)
  • the flow editor is used to create flows
  • the dashboard is used for.....dashboard
Why not covert the html to json and display output in the debug panel ?
Why not creating a bookmark for the dashboard ?
we have flows where in which end user clicks only on execute = more of a non technical operation and interested to see final output in a new tab or new browser and not within flow editor(like debug pane)
bookmark is the last option if nothing works out.
I also tried node-red-java-contrib function to redirect to dashboard as mentioned in section 3 of https://flows.nodered.org/node/node-red-contrib-java-function but
Desktop.getDesktop().browse(uri)
takes the system where node red is installed (m2) and not the current machine (m1)
Any suggestions to achieve this would be of great help !
So why not move "execute" to a dashboard and display the output in the same view ?
Could you explain this please
Move the execute to the same tab (ie. dashboard)
Use a button in the dashboard to start the flow
