There’s a great page in the docs (Working with messages : Node-RED) that will explain how to use the debug panel to find the right path to any data item.
Thanks, I was hopinh that there would be a special BACnet node available to enable me to quickly select the present value, but I'll take a deeper dice into the structures, thanks again.
