Hi
I want to show specific dashboards on a rotating screen every 3 seconds.
For example, I want to show the camera dashboard and show the sensor dashboard after 3 seconds. I want to repeat this.
How should it be configured?
thanks
Take a look at the ui-control node. By passing it {"tab":1} (as a JSON object) it will switch to that tab.
Then all you need do is change the number (starting with 0) to go to another tab. You could do that a number of ways:
inject nodes set to fire every 9 seconds with the first to fire at deploy, the second to fire after 3 seconds and the third to fire after 6 seconds.And I'm sure others will offer other solutions.
thanks
great it works.well!!
