Hi There,
is there a simple way to find packages the provide specific node types? For example like this:
turns out when I search for string, I get this:
the package in red actually provides the node type string that I was looking for.
Already works but no filter needed. Just search the type.
A filter will be added in a futur version
Part of the palette improvements. I don't know if Nick plans to integrate it into 4.1. There's already a lot of stuff.
You did look at the second screenshot? Yes it works but can you tell me which of the packages provide the string node type?
The one I highlighted was the package I found myself (by searching by type) - the point is that searching for "string" results in 30+ packages but which one provides the node type string?
Can you tell me that from the second screenshot?
Great so this will happen sometime in the future. Ok, well then I'll just wait until the future comes.
EDIT: for those that might need this now, there is a flow that filters all packages by node types.
I edited my message at the same time. So to answer you, a filter will be added but I don't know if it's planned for v4.1.
The search works on types but is not exclusive, I mean types, name, keywords are also included.
