It is a feature for "quick node placement". It allows you to quickly add a new node by typing its name, instead of draging it from the palette. But for some weird reason there is no input rendered for you.
If you are stuck then try refreshing the browser page, I suspect that will sort it.
Sometimes the most simple things to the trick ![]()
Thank you Colin.
