i´m still at the beginning using HA and Node Red. I´m at a point where i like to use Node Red for small automations.
Where I am currently failing is the physical switching of relays that are connected to the Pi. In the HA Dashboard I manage to switch the two relays back and forth. When I use Node Red, the relays switch in the flow, but not physically.
Is it somehow because I have installed rpi_gpio in the configuration under custom components and declared the GPIOs in configuration.yaml?
I have attached some screenshots.
Thank you
Answers are also welcome in German ![]()
Translated with DeepL.com (free version)
