Greetings all,
I have node red v3.1.5 & node JS v20.11.1
I am creating a simple dashboard with 3 buttons and form as "input" group and a table as an "output" group all under one tab "test dashboard"
after deploying and running the dashboard, table just appears and all input group nodes disappearing.
- I checked in the final layout on the tab that, the table is not overriding other nodes.
- I didn't create a CSS file, I am using node red theme.
- I restarted node-red and the browser and still the same issue.
- I tried to use old versions of node red and node JS, the same problem.
after removing the table and restart node-red other input nodes appears on the dashboard correctly.
so what could be the reason that ui_table override other dashboard nodes?
