Telegram node error
Hi all!.
I have been using the Telegram RedBot node without problem, but with some reason it says me this error image
I get this error using a function node after the telegram redbot node, maybe it has something to do with it.
And if i replace the telegram node with this one image i get this error image
Thanks a lot!
I would suggest the Error 409 is indicating your issue. You cannot run more than one bot instance per device. Are you?
Yes i know what the error means. The thing is why i cannot use two versions of telegram node at the same time?
And i weird the other error i get using the redbot node telegram.
Anyone could fix this error?
Thanks!
Most of us don't use the redbot nodes I don't think but rather the simpler telegram nodes.
If there is an issue with the redbot nodes, you will need to raise an issue on the authors GitHub.
