I can only wire the debugs to the firs port of switch.
like this.
Anybody knows why?
Hi @bupeigon , welcome to the forum.
Some questions to help us understand what you're experiencing:
Nick
Hi Nick, appreciate for your help.
I am using version: v2.1.4, and the browser I am using is Edge.
For your third question, the truth is I can’t even drag a wire from any output of the switch node,
and I can only wire the two nodes from the input to the place being left to the output.
Can you wire other nodes properly? Is it only the Switch node that shows the problem?
Have you checked the browser's JavaScript console for any errors when you try to wire from the Switch node's output?
Have you tried a different browser so we can see if this is something specific to Edge?
I can’t wire them.
Try forcing a cache clear in the browser, via the menus. Also, if possible, try a different browser.
Thank you. When I switch the browser, the switch is gonna be okay.
Maybe it’s the problem of Edge.
Does this issue occur with the old Edge or new chrome based Edge?
What version of Edge?
Can you please see if there are any errors in the browsers console when this happens (F12 --> console)
It isn't a problem with Edge. I use Edge with Node-RED all the time. The Chromium version of Edge, the old version is no longer valid and should not be used.
Have you tried clearing the cache via the browser menus?
Yes, I’ve tried
OK. You still haven't said which version of Edge and whether the browser console shows any errors.
That mentions userscript.html. I would suggest that maybe you've got a userscript extension installed and that is causing an issue.
