Hello everyone,
I am new to node red. I have made 3 ui tabs using node red. I want to lock two ui dashboard tabs using keypad lock. when I enter my 4 digit pin in to the keypad that should redirect me to my other tabs else it should be locked.
thanks in advance.
Hi & welcome to the forum.
which part are you stuck on?
- collecting the inputs?
- checking the input against a stored code?
- redirecting user?
Perhaps if you share your flows we can spot an issue?
These are the node that i got for keypad lock. if pin_ok works that should redirect me to the one of the tab that i have created. otherwise those two tab should be locked and not accessible.
is that possible?
Thanks and regards.
Bhavesh Solanki
