Trouble with OPC UA String datatypes from M251 PLC
  • Schneider Electric PLC: TM251MESE
  • Firmware: V5.2.11.24
  • PLC Software: Machine Expert V2.2.2 (Codesys based)
  • OPC UA Browser: UA Expert 1.7.1
  • node-red nodes: node-red-contrib-opcua 0.2.339 / @opcua/for-node-red 3.8.0
  • Node Red: V4.0.9
I'm running into an issue with reading strings out of the OPC UA server in my PLC. Often the string value in the PLC don't match in the couple of node-red nodes I've tried so far. Using UA Expert, the string values always match the PLC.
What happens is that the strings in node-red can sometimes have garbage characters or remnants of the last message read from the PLC.
This picture shows the values not matching between the three software's. I had set the string to be empty in the PLC and remnant values stayed in the node-red.
This one shows remnants being attached to the end of the null in the message. It should be AAA1 and that's it.
I've attached my flow to see if I could get assistance with this.
        "id": "e8a37527a489be6a",
        "type": "tab",
        "label": "Debug Flow",
        "disabled": false,
        "info": "",
        "env": []
        "id": "c64e272d41a2adad",
        "type": "comment",
        "z": "e8a37527a489be6a",
        "name": "Read the tag values from PLC over OPC UA",
        "info": "",
        "x": 210,
        "y": 80,
        "id": "aa7eff6a65a94761",
        "type": "OpcUa-Item",
        "item": "ns=2;s=Memory_Words.CODES[0]",
        "datatype": "String",
        "value": "",
        "name": "codes",
        "x": 370,
        "y": 120,
                "1efbb414347444f3"
        "id": "d51ce7ac3affe287",
        "type": "function",
        "name": "String Clean",
        "func": "if (typeof msg.payload === \"string\") {\n    // Split at the first null character (if any) and trim any extra spaces.\n    let cleaned = msg.payload.split(\"\\0\")[0].trim();\n    msg.payload = cleaned;\n}\nreturn msg;",
        "outputs": 1,
        "timeout": 0,
        "noerr": 0,
        "initialize": "",
        "finalize": "",
        "libs": [],
        "x": 890,
        "y": 100,
                "d57c8cf01f98280a"
        "id": "d57c8cf01f98280a",
        "type": "debug",
        "name": "Cleaned",
        "active": true,
        "tosidebar": true,
        "console": false,
        "tostatus": false,
        "complete": "payload",
        "targetType": "msg",
        "statusVal": "",
        "statusType": "auto",
        "x": 1080,
        "y": 200,
        "id": "db4e604075f499b6",
        "type": "debug",
        "name": "Payload",
        "active": false,
        "tosidebar": true,
        "console": false,
        "tostatus": false,
        "statusVal": "",
        "x": 800,
        "y": 200,
        "id": "1efbb414347444f3",
        "type": "OpcUa-Client",
        "endpoint": "a3af1c676fc10c9c",
        "action": "subscribe",
        "deadbandtype": "a",
        "deadbandvalue": 1,
        "time": "200",
        "timeUnit": "ms",
        "certificate": "n",
        "localfile": "",
        "localkeyfile": "",
        "securitymode": "None",
        "securitypolicy": "None",
        "useTransport": false,
        "maxChunkCount": 1,
        "maxMessageSize": 8192,
        "receiveBufferSize": 8192,
        "sendBufferSize": 8192,
        "setstatusandtime": false,
        "keepsessionalive": false,
        "x": 620,
        "y": 120,
                "db4e604075f499b6",
                "d51ce7ac3affe287"
        "id": "6f6ee340ec4eaf29",
        "type": "inject",
        "props": [
                "p": "payload"
                "p": "topic",
                "vt": "str"
        "repeat": "",
        "crontab": "",
        "once": false,
        "onceDelay": 0.1,
        "topic": "",
        "payload": "",
        "payloadType": "date",
        "x": 140,
        "y": 120,
                "aa7eff6a65a94761"
        "id": "a3af1c676fc10c9c",
        "type": "OpcUa-Endpoint",
        "endpoint": "opc.tcp://110.8.34.2:4840",
        "secpol": "None",
        "secmode": "None",
        "none": true,
        "login": false,
        "usercert": false,
        "usercertificate": "",
        "userprivatekey": ""
