Troubleshoot Reconnect error in Dashboard
I have node-red running in docker.
I see that this question is asked a lot. I get an error when I go to the dashboard.
If I check the log I don't see much usefull info :
The last line was me restarting the Zigbee2Mqtt image.
How can I troubleshoot this?
Welcome to the forum.
Are you running the browser in the same machine that is running node-red?
Are you using the IP address of the node-red docker container?
Do you have a good reason for using docker? If not then don't.
I have found the problem. It was my Ngnix Proxy Manager. I had to enable websockets and then it worked.
