Hello everyone,
It's been a while since I published an update on the forums, so you know... here it is.
I have just released V9 of node-red-contrib-zwave-js.
V9 has some breaking changes, and importantly contains some deprecations that you need to prepare yourself with, for when the next major release (v10) is made available
V10 is being worked (and in fact, was started before v9)
V10 will likely be my biggest challenge, as its re-writing the entire code base from scratch using typescript, not to mention a massive UI re-write.
But more on that closer to the time, for now please see below for V9
Breaking Changes
- The min node version is now 18
- If you execute certain methods your self, the following have been renamed
beginHealingNetwork->beginRebuildingRoutesstopHealingNetwork->stopRebuildingRouteshealNode->rebuildNodeRoutes
New Features
- Added
getValueTimestampto theValue API- args will be the single Value ID
The event will beVALUE_TIMESTAMP
Changes
- Bump ZWave JS to v12
- The
lastSeenproperty will now use the Drivers internal value, which is persistant between reboots
Deprecations
- The old message format has now been deprecated, and support will be removed in V10.
PLEASE SEE MIGRATION GUIDE - Support for
responseThroughEventwill be removed in V10 (all methods will return in v10) - Support for
forceUpdatewill be removed in V10 (you will be required to manage this your self if using the CC API) - Support for
getLastEventswill be removed in V10.
(the introdcution of the persistantlastSeenvalue andgetValueTimestamphas made this somewhat bloatware)
