Using blockly timer section
Hi, I am trying to script a timer function using blockly, i can start a timer and stop it using blockly but i need to be able to restart the timer BEFORE it completes its present timer setting. eg 10 seconds into its 30 second time operation it may be requested to restart the timing.
I am unable to solve this and hope someone will be kind enough to help me?
thanks
Simon @cymplecy is the blockly expert!
Thank you
I've tried to program something similar and failed so I can't help
It didn't actually fail but it did cause warning errors to appear so it wasn't a nice solution
thank you for replying anyway
I'll try and dig up what I did :slight_smile:
I think i have done it or at least the beginnings of :slight_smile:
        "id": "775258288b8ca03e",
        "type": "debug",
        "z": "f396d031fe5c8965",
        "name": "debug 95",
        "active": true,
        "tosidebar": false,
        "console": false,
        "tostatus": true,
        "complete": "payload",
        "targetType": "msg",
        "statusVal": "payload",
        "statusType": "auto",
        "x": 1040,
        "y": 460,
        "id": "86d14da29090ac75",
        "type": "Blockly",
        "func": "if ((msg['payload']) == 'start') {\n  var timeout_1 = setTimeout(function() {\n    node.send([msg]);\n  }, 10000);\n  context.set(\"timeout_1\", timeout_1);} else if ((msg['payload']) == 'stop') {\n  if (context.get(\"timeout_1\")) {\n    clearTimeout(context.get(\"timeout_1\"));\n    context.set(\"timeout_1\", undefined);\n  }\n  node.send([msg]);\n} else if ((msg['payload']) == 'restart') {\n  if (context.get(\"timeout_1\")) {\n    clearTimeout(context.get(\"timeout_1\"));\n    context.set(\"timeout_1\", undefined);\n  }\n  var timeout_1 = setTimeout(function() {\n    node.send([msg]);\n  }, 10000);\n  context.set(\"timeout_1\", timeout_1);}\n",
        "workspaceXml": "<xml xmlns=\"https://developers.google.com/blockly/xml\">\n  <block type=\"controls_if\" id=\"d-gJ+-Lq}:E?Ih`(p.L#\" x=\"-262\" y=\"-212\">\n    <mutation elseif=\"2\"></mutation>\n    <value name=\"IF0\">\n      <block type=\"logic_compare\" id=\"7h)4nWxurO74^2RHro/Y\">\n        <field name=\"OP\">EQ</field>\n        <value name=\"A\">\n          <block type=\"node_object_get\" id=\"se?zaAa=tm4q#6:Q:Ar7\">\n            <mutation xmlns=\"http://www.w3.org/1999/xhtml\" action=\"GET\"></mutation>\n            <field name=\"action\">GET</field>\n            <value name=\"object\">\n              <shadow type=\"node_msg\" id=\"^_=%(?!Ye.|7|GlE!*/:\"></shadow>\n            </value>\n            <value name=\"field_name\">\n              <shadow type=\"text\" id=\"tKCxp.A,}yFs[O)H$._R\">\n                <field name=\"TEXT\">payload</field>\n              </shadow>\n            </value>\n          </block>\n        </value>\n        <value name=\"B\">\n          <block type=\"text\" id=\"Jcw3~FeMIhlH4#z`!)13\">\n            <field name=\"TEXT\">start</field>\n          </block>\n        </value>\n      </block>\n    </value>\n    <statement name=\"DO0\">\n      <block type=\"set_timeout\" id=\"4.)r.V*t|qjH@SN}qG1f\">\n        <field name=\"NAME\">timeout_1</field>\n        <field name=\"DELAY\">10</field>\n        <field name=\"UNIT\">sec</field>\n        <statement name=\"STATEMENT\">\n          <block type=\"node_send\" id=\"zK9w]#-iTIp+3IuZ-lCN\">\n            <field name=\"OUTPUT_NR\">1</field>\n            <value name=\"MESSAGE_INPUT\">\n              <shadow type=\"node_msg\" id=\",YwLpM.![IK!RaW.(tv|\"></shadow>\n            </value>\n          </block>\n        </statement>\n      </block>\n    </statement>\n    <value name=\"IF1\">\n      <block type=\"logic_compare\" id=\"()Jk[]VL=p~QT96S!S%g\">\n        <field name=\"OP\">EQ</field>\n        <value name=\"A\">\n          <block type=\"node_object_get\" id=\"RCoifxD7I,{]I34`@|{*\">\n            <mutation xmlns=\"http://www.w3.org/1999/xhtml\" action=\"GET\"></mutation>\n            <field name=\"action\">GET</field>\n            <value name=\"object\">\n              <shadow type=\"node_msg\" id=\"=9)a6t./UZPuXO%$a,^{\"></shadow>\n            </value>\n            <value name=\"field_name\">\n              <shadow type=\"text\" id=\"(EhRL;{@6o4k2dlL1@{2\">\n                <field name=\"TEXT\">payload</field>\n              </shadow>\n            </value>\n          </block>\n        </value>\n        <value name=\"B\">\n          <block type=\"text\" id=\"1pLJ*h?#.%^u8PALoKyI\">\n            <field name=\"TEXT\">stop</field>\n          </block>\n        </value>\n      </block>\n    </value>\n    <statement name=\"DO1\">\n      <block type=\"clear_timeout\" id=\"Nk+g`6knu_(;$?Q;qc?A\">\n        <mutation xmlns=\"http://www.w3.org/1999/xhtml\" dropdown_options=\"{&quot;nothing_selected&quot;:&quot;none&quot;,&quot;4.)r.V*t|qjH@SN}qG1f&quot;:&quot;timeout_1&quot;,&quot;H_l(`BM?,l!vYpDe^{=N&quot;:&quot;timeout_1&quot;}\"></mutation>\n        <field name=\"NAME\">4.)r.V*t|qjH@SN}qG1f</field>\n        <next>\n          <block type=\"node_send\" id=\"q95KnJCwwhxL5!r75?8w\">\n            <field name=\"OUTPUT_NR\">1</field>\n            <value name=\"MESSAGE_INPUT\">\n              <shadow type=\"node_msg\" id=\"KL(A+95*L-p!Y}mg=_Cf\"></shadow>\n            </value>\n          </block>\n        </next>\n      </block>\n    </statement>\n    <value name=\"IF2\">\n      <block type=\"logic_compare\" id=\"q0W=e`3/a~hO8`E(gd=,\">\n        <field name=\"OP\">EQ</field>\n        <value name=\"A\">\n          <block type=\"node_object_get\" id=\"npKWA!.@:4GB5-/z?E[A\">\n            <mutation xmlns=\"http://www.w3.org/1999/xhtml\" action=\"GET\"></mutation>\n            <field name=\"action\">GET</field>\n            <value name=\"object\">\n              <shadow type=\"node_msg\" id=\"xSl@3VU(1P%#qEA0(,X!\"></shadow>\n            </value>\n            <value name=\"field_name\">\n              <shadow type=\"text\" id=\"jGklls{0UOq4vB-VXDzw\">\n                <field name=\"TEXT\">payload</field>\n              </shadow>\n            </value>\n          </block>\n        </value>\n        <value name=\"B\">\n          <block type=\"text\" id=\"n8U?]*.9`FdW%5Zq|M+%\">\n            <field name=\"TEXT\">restart</field>\n          </block>\n        </value>\n      </block>\n    </value>\n    <statement name=\"DO2\">\n      <block type=\"clear_timeout\" id=\"-_bWB.AvI%~}9,/{42Iu\">\n        <mutation xmlns=\"http://www.w3.org/1999/xhtml\" dropdown_options=\"{&quot;nothing_selected&quot;:&quot;none&quot;,&quot;4.)r.V*t|qjH@SN}qG1f&quot;:&quot;timeout_1&quot;,&quot;H_l(`BM?,l!vYpDe^{=N&quot;:&quot;timeout_1&quot;}\"></mutation>\n        <field name=\"NAME\">4.)r.V*t|qjH@SN}qG1f</field>\n        <next>\n          <block type=\"set_timeout\" id=\"H_l(`BM?,l!vYpDe^{=N\">\n            <field name=\"NAME\">timeout_1</field>\n            <field name=\"DELAY\">10</field>\n            <field name=\"UNIT\">sec</field>\n            <statement name=\"STATEMENT\">\n              <block type=\"node_send\" id=\"dol5Ocqaak0lz8NOvEi?\">\n                <field name=\"OUTPUT_NR\">1</field>\n                <value name=\"MESSAGE_INPUT\">\n                  <shadow type=\"node_msg\" id=\"E[#SQ.`@:)38cSfbp#MQ\"></shadow>\n                </value>\n              </block>\n            </statement>\n          </block>\n        </next>\n      </block>\n    </statement>\n  </block>\n</xml>",
        "outputs": 1,
        "timeout": 0,
        "blocklyConfig": "49b50d82dba520c7",
        "backpackContents": [],
        "noerr": 0,
        "x": 880,
        "y": 460,
                "775258288b8ca03e"
        "id": "5801af9ae34c0125",
        "type": "inject",
        "props": [
                "p": "payload"
        "repeat": "",
        "crontab": "",
        "once": false,
        "onceDelay": 0.1,
        "topic": "",
        "payload": "start",
        "payloadType": "str",
        "x": 710,
        "y": 460,
                "86d14da29090ac75"
        "id": "fcb5838615df7c8b",
        "type": "inject",
        "props": [
                "p": "payload"
        "repeat": "",
        "crontab": "",
        "once": false,
        "onceDelay": 0.1,
        "topic": "",
        "payload": "stop",
        "x": 710,
        "y": 500,
                "86d14da29090ac75"
        "id": "e0f0d27e46db34f9",
        "type": "inject",
        "props": [
                "p": "payload"
        "repeat": "",
        "crontab": "",
        "once": false,
        "onceDelay": 0.1,
        "topic": "",
        "payload": "restart",
        "x": 710,
        "y": 540,
                "86d14da29090ac75"
        "id": "49b50d82dba520c7",
        "type": "blockly-config",
        "language": "en",
        "showTrashcan": true,
        "allowComments": true,
        "showZoomControl": true,
        "showMiniMap": true,
        "enableBackPack": false,
        "toolboxPosition": "left",
        "renderer": "zelos",
        "theme": "classic",
        "categories": [
                "name": "Node-RED",
                "files": [
                    "blockly-contrib/npm/node-red-contrib-blockly/lib/nodered/nodeRedBlocksCodeGen.js",
                    "blockly-contrib/npm/node-red-contrib-blockly/lib/nodered/nodeRedBlocksDefs.js",
                    "blockly-contrib/npm/node-red-contrib-blockly/lib/nodered/toolbox.xml",
                    "blockly-contrib/npm/node-red-contrib-blockly/messages/en.js"
                "name": "Objects",
                "files": [
                    "blockly-contrib/npm/node-red-contrib-blockly/lib/json/objectBlocksCodeGen.js",
                    "blockly-contrib/npm/node-red-contrib-blockly/lib/json/objectBlocksDefs.js",
                    "blockly-contrib/npm/node-red-contrib-blockly/lib/json/toolbox.xml",
                "name": "Buffer",
                "files": [
                    "blockly-contrib/npm/node-red-contrib-blockly/lib/buffer/bufferBlocksCodeGen.js",
                    "blockly-contrib/npm/node-red-contrib-blockly/lib/buffer/bufferBlocksDefs.js",
                    "blockly-contrib/npm/node-red-contrib-blockly/lib/buffer/toolbox.xml",
                "name": "Date/time",
                "files": [
                    "blockly-contrib/npm/@blockly___SEPARATOR___field-date/dist/index.js",
                    "blockly-contrib/npm/node-red-contrib-blockly/lib/datetime/dateTimeBlocksCodeGen.js",
                    "blockly-contrib/npm/node-red-contrib-blockly/lib/datetime/dateTimeBlocksDefs.js",
                    "blockly-contrib/npm/node-red-contrib-blockly/lib/datetime/toolbox.xml",
                "name": "Timer",
                "files": [
                    "blockly-contrib/npm/node-red-contrib-blockly/lib/timer/timerBlocksCodeGen.js",
                    "blockly-contrib/npm/node-red-contrib-blockly/lib/timer/timerBlocksDefs.js",
                    "blockly-contrib/npm/node-red-contrib-blockly/lib/timer/toolbox.xml",
                "name": "Blockly extension",
                "files": [
                    "blockly-contrib/npm/node-red-contrib-blockly/lib/extra/extraBlocksCodeGen.js",
                    "blockly-contrib/npm/node-red-contrib-blockly/lib/extra/extraBlocksDefs.js",
                    "blockly-contrib/npm/node-red-contrib-blockly/lib/extra/toolbox.xml",
                "name": "Blockly standard",
                "files": [
                    "blockly-contrib/npm/node-red-contrib-blockly/lib/basic/toolbox.xml"
        "customizeToolbox": false,
        "name": "blo-config"
Much simpler solution . if start is resent timer_1 just stops itself and restarts.
        "type": "debug",
        "name": "debug 95",
        "active": true,
        "tosidebar": false,
        "console": false,
        "tostatus": true,
        "x": 1040,
        "y": 460,
        "type": "Blockly",
        "outputs": 1,
        "timeout": 0,
        "noerr": 0,
        "x": 880,
        "y": 460,
                "775258288b8ca03e"
        "type": "inject",
        "props": [
                "p": "payload"
        "repeat": "",
        "crontab": "",
        "once": false,
        "onceDelay": 0.1,
        "topic": "",
        "payload": "start",
        "x": 710,
        "y": 460,
                "86d14da29090ac75"
        "type": "inject",
        "props": [
                "p": "payload"
        "repeat": "",
        "crontab": "",
        "once": false,
        "onceDelay": 0.1,
        "topic": "",
        "payload": "stop",
        "x": 710,
        "y": 500,
                "86d14da29090ac75"
        "type": "inject",
        "props": [
                "p": "payload"
        "repeat": "",
        "crontab": "",
        "once": false,
        "onceDelay": 0.1,
        "topic": "",
        "x": 710,
        "y": 540,
                "86d14da29090ac75"
        "language": "en",
        "theme": "classic",
        "categories": [
                "name": "Node-RED",
                "files": [
                "name": "Objects",
                "files": [
                "name": "Buffer",
                "files": [
                "files": [
                "name": "Timer",
                "files": [
                "files": [
                "files": [
