hi @marcus-j-davies installed the new version changed my flows as instructed, All working very well !
Thank you
As a side note how do i use transitionduration?
I was hoping to switch on a binary input then using the duration switch it off ? is this what it is designed for?
Please forgive my question if it seems simple but its a learning curve for me.
Thanks again for a wonderful node
Hi @magicman
transitionDuration needs to be supported by the target device for it to have an effect.
it can be used to say change the value of a multilevel switch (dimmer), or an RGB controller (transition to a different colour)
/* Dimming down a light (Multilevel Switch) over 3s */
const Node = 5;
const ValueID = {
commandClass: 0x26,
endpoint: 0,
property: 'targetValue'
const SetValueOptions = {
transitionDuration: '3s',
msg.payload = {
cmd: {
api: 'VALUE',
method: 'setValue'
cmdProperties: {
nodeId: Node,
valueId: ValueID,
value: 25, /* Say from its current value of 100 */
setValueOptions: SetValueOptions
I have never had a device that I can test this with - but it's a set value option in the Driver, that this is designed for.
It could work for a binary switch, as long as its supported by the device
EDIT
The above is verbose of course, but the Factory Node has full support for applying options ![]()
