Hi
Im running node red on a raspberry pie 3 (b+) with Hassio.
Hassio 0.86.4
Node red 1.3.0
I while a go I started to get connection problems when deploying a new flow in node red, see below. Any one got an idea what it may depend on?
Is there any way I can delay the service calls for 5 second when doing a deploy?
//Johan
7 Feb 22:09:40 - [info] Stopping flows
7 Feb 22:09:40 - [info] [server:Home Assistant] Closing WebSocket http://hassio/homeassistant
7 Feb 22:09:40 - [info] Stopped flows
7 Feb 22:09:40 - [info] Starting flows
7 Feb 22:09:40 - [info] Started flows
7 Feb 22:09:41 - [warn] [api-call-service:Turn on Stars] Call-Service attempted without connection to server.
7 Feb 22:09:41 - [warn] [api-call-service:Turn on Julbelysning framsida] Call-Service attempted without connection to server.
7 Feb 22:09:41 - [warn] [api-call-service:Turn on Fontän] Call-Service attempted without connection to server.
7 Feb 22:09:41 - [warn] [api-call-service:Turn On Vardagsrum] Call-Service attempted without connection to server.
7 Feb 22:09:41 - [warn] [api-call-service:Guldlampa på] Call-Service attempted without connection to server.
7 Feb 22:09:41 - [warn] [api-call-service:Fönsterlamp kök] Call-Service attempted without connection to server.
7 Feb 22:09:41 - [warn] [api-call-service:Fönsterlamp Vardagsrum] Call-Service attempted without connection to server.
7 Feb 22:09:41 - [warn] [api-call-service:Turn On Växtlampa tvättstuga] Call-Service attempted without connection to server.
7 Feb 22:09:41 - [warn] [api-call-service:Turn Off Växtlampa förråd] Call-Service attempted without connection to server.
7 Feb 22:09:41 - [warn] [api-call-service:Turn Off Motorvärmare] Call-Service attempted without connection to server.
7 Feb 22:09:45 - [info] [server:Home Assistant] WebSocket Connected to http://hassio/homeassistant
