Websocket Timeout Issue/Phoscon
I am using a Raspberry Pi 3 with Node Red/DeCONZ/Phoscon Apps to monitor and control home automation devices wirelessly using the Zigbee network and ConBee II. Every so often on the Node Red console I see the following warning "[deconz-server:Phoscon-GW] Websocket connection timeout, reconnecting." When this happens all deConz in nodes in my flows disconnect for 15 or 20 seconds. Then they reconnect and everything works again like it should.
Can someone please tell me what is causing this error and how to fix it?
Thank you,
Scott
Hi, @ScottJ2505 did you manage to fix this timeout issue ? I'm facing the same problem.
No, unfortunately I still have the same issue.
I have not focused too much on fixing the problem and am putting up with it. But it impacts so a small degree my smart home devices.
Perhaps we can work together to try and solve the issue.
My email address is ScottJ2505@aol.com if you wish to contact me directly.
Best regards,
Scott
