Has anyone ever run across the below screenshot. Node-red on a Raspberry Pi4 became unresponsive so I restarted via terminal and now get this screen in the designer.
Hi.
What version of node-red are you running?
Did you import any flows? (From web/chatgpt etc)
Can you look in the browser's developer tools console and check to see if there are any errors?
Version 4.0.2
Everything had been working fine for a while. I hadn't imported any new flows in quite a while.
injectedScript.bundle.js is NOT something node-red serves as part of the application.
That looks like a browser extension or something.
Try a different browser, or try with extensions disabled,
I opened in incognito window and it opened fine then forced a hard refresh in the regular window and that fixed it. Thanks for the help - I should have tried that first.
