What happens when Flows file not found?
The log tells me:
dd Mmm hh:mm:ss - [info] Flows file     : /home/pi/.node-red/flows_raspberrypi.json
dd Mmm hh:mm:ss - [info] Creating new flow file
So it says it's created a new file, but I don't see a flows_raspberrypi.json file appear in the /home/pi/.node-red/ directory.
Should I, or is it just some sort of a temporary or "virtual" file?
Asking out of curiosity rather than it being a problem or anything needing fixing.
On Raspberry Pi.
It will only actually create the file when you deploy something from the editor.
That makes sense - thanks.
