Hi.
I don´t know what happened but when i try to edit my functions the indent of the text is weird.
I am using the last version of node-red in windows 11, i tried in 2 different pcs an with chrome, firefox and brave browsers
Solved. I uninstall the @fdecourt/node-red-contrib-groq node and the problem dissapeared
Oh boy, a node should not be able to cause something like that!
It would be good to raise an issue against that node if you can.
Welcome to the community by the way.
I was going to make a joke about you probably living near the equator which is why your text has all slid to one side, but I'm guessing you wouldn't have appreciated it! ![]()
At the end of the day, it's all html and CSS. If a node doesn't scope its CSS it will affect other nodes.
An issue should be raised. The author may not be aware off this.
