I to all
I want user alexa home skill node for ask : Alexa read temperature"
then using alexa node Home Response i tell the poi of my house "garden"
then into my nodered flow read the request "read temperrature" and "garden"
i look alexa home response is possible give to alexa second command but not find a example to follow
I don't think you can do exactly what you want but you could try using the alexa-remote2 node on its own with the Q&A skill and set up question like
"Alexa, read garden temperature"
and then check when its received
See Get number from Alexa - #5 by E1cid
but also note that I have reliability issues
I've been using alexa-remote2 a bit recently (coupled with the Q&A skill) as per this useful thread
but I'm finding its not quite reliable enough (compared to using @hardillb https://flows.nodered.org/node/node-red-contrib-alexa-home-skill ) for everyday use and I'm wondering is it just my setup or do others have same issue
Basically, I find that if I say "alexa fast forward" - if alexa is successfully triggered, then it picks this the spoken phrase 100% of the time and the activity node ou…
E1cid
11 April 2020 12:19
3
I also found this today which may help
build alexa google skills with no coding.
system
Closed
10 June 2020 12:19
4
