Changing configuration of node-red-contrib-bigtimer
I was trying to use node-red-contrib-bigtimer .
I did not see a feature to change all the configuration which we set inside the node using Inject or inputs .
Say I checked Sun and Mon for scheduling events on these days inside node.
Can I inject and change this settings using some inputs ?.
I want all the configuration changed using some GUI .Does the node allows this ?.
I did not see any documentation on this .
I know that few settings we can override .
Bigtimer was written for other purposes I think and so I don't think it has the features you are looking for. However, the cron-plus node certainly does.
Thank you for the information. Yes I did not see any option enable/disable the days I set in node using inject .
cron-plus seems very flexible.
