[Flexdash] Which url on home assistant?
I've installed nodered as addon on home assistant.
I've installed flexdash via Manage Palette (@flexdash/node-red-fd-corewidgets)
I've load the Hello world example
and now, i don't find the url to go to see my dashboard...
tried
Any ideas ? Thanks in advance !
The correct access url should be http://ha-dev2.local:1880/flexdash (if you access your node-RED on port 1880).
Have you tried restarting node-RED?
Finally, it works after restarting home assistant and use the url
http://ha-dev2.local:1880/endpoint/flexdash
Thanks for you help !
Is that not the URL that is shown in the FlexDash Dashboard config node edit panel (what @smanjunath211 pasted)? Or was the issue that HA needed a restart?
It was a problem with the restart, but you also need to change the port.
