Flic - iHost Hub by SonOff
Thinking it was an answer to a solved step, yes! But not the topic, gotcha ...
Cool now I know what 7/61 means , unchecked.
Thankyou.
So I cannot update a page (28/61) but I can reply to it.
(edit)
Update for Node-red but version code is not updated ?
2024-05-28T14:04:28 :rocket: ~ file: baseClass.ts:320 ~ baseClass ~ initSSE ~ url http://192.168.2.109/open-api/v1/sse/bridge?access_token=b73b72e6-d1b3-4e12-b3b6-ba197ddc330d
Sure you can - it is your post
chrome_ZjEeZfvTko
Also, you dont need to type out 28/61 you can copy+paste a link direct to it:
example: Flic - iHost Hub by SonOff - #28 by Y2K
Oh that is so cool that you have an animated screen,
I eventually found that I may have been looking at a reply of my original post.
I also found out that my ewelink stopped running in the background so I will keep this in mind. Too many things going on here.
But I still would like to know how flic buttons work with ihost.
I went from a connection closed error to a connected then back to a connection closed error.
And now I have a count with my NS panel, so far so good I have one device with a live feedback now.
Also my Bell 3000 Hub is new to me , probably also obsolete, probably not matter compliant - reliant , that means it is still not reliable. Or maybe HomeKit it cause us grief again.
Question has not been answered.
Can node red be used on iHost ?
Meross - no
Flic - no
LifX - no
Yes. In my case I run Alexa, eWelink Cube, Smartthings and Philips Hue among others. Cannot speak for the examples you name, but each case is different depending on that node. Sometimes worth going to the forum for that manufacturer.
