Artwin
24 January 2020 12:05
1
every time I input firebase URL and I use auth type json web token, and fill Child Path with "Sensor", Method with "Push ()" and value with "msg.payload" and done.
then I deploy and immediately my Node-RED stops with an ELIFECYCLE error like the picture above, does anyone know why that happened?
Artwin
24 January 2020 13:18
3
0 info it worked if it ends with ok
1 verbose cli [
1 verbose cli 'C:\Program Files\nodejs\node.exe',
1 verbose cli 'C:\Program Files\nodejs\node_modules\npm\bin\npm-cli.js',
1 verbose cli 'start'
1 verbose cli ]
2 info using npm@6.12.0
3 info using node@v12.13.0
4 verbose run-script [ 'prestart', 'start', 'poststart' ]
5 info lifecycle node-red@1.0.3~prestart: node-red@1.0.3
6 info lifecycle node-red@1.0.3~start: node-red@1.0.3
7 verbose lifecycle node-red@1.0.3~start: unsafe-perm in lifecycle true
8 verbose lifecycle node-red@1.0.3~start: PATH: C:\Program Files\nodejs\node_modules\npm\node_modules\npm-lifecycle\node-gyp-bin;E:\NodeRedC\node-red\node_modules.bin;C:\Windows\system32;C:\Windows;C:\Windows\System32\Wbem;C:\Windows\System32\WindowsPowerShell\v1.0;C:\Windows\System32\OpenSSH;C:\Program Files\Git\cmd;C:\Program Files\nodejs;C:\Program Files\PuTTY;C:\Program Files\MATLAB\R2008a\bin;C:\Program Files\MATLAB\R2008a\bin\win64;C:\Users\Artwin\AppData\Local\Microsoft\WindowsApps;C:\Users\Artwin\AppData\Roaming\npm
9 verbose lifecycle node-red@1.0.3~start: CWD: E:\NodeRedC\node-red
10 silly lifecycle node-red@1.0.3~start: Args: [ '/d /s /c', 'node packages/node_modules/node-red/red.js' ]
11 silly lifecycle node-red@1.0.3~start: Returned: code: 3221226505 signal: null
12 info lifecycle node-red@1.0.3~start: Failed to exec start script
13 verbose stack Error: node-red@1.0.3 start: node packages/node_modules/node-red/red.js
13 verbose stack Exit status 3221226505
13 verbose stack at EventEmitter. (C:\Program Files\nodejs\node_modules\npm\node_modules\npm-lifecycle\index.js:332:16)
13 verbose stack at EventEmitter.emit (events.js:210:5)
13 verbose stack at ChildProcess. (C:\Program Files\nodejs\node_modules\npm\node_modules\npm-lifecycle\lib\spawn.js:55:14)
13 verbose stack at ChildProcess.emit (events.js:210:5)
13 verbose stack at maybeClose (internal/child_process.js:1021:16)
13 verbose stack at Process.ChildProcess._handle.onexit (internal/child_process.js:283:5)
14 verbose pkgid node-red@1.0.3
15 verbose cwd E:\NodeRedC\node-red
16 verbose Windows_NT 10.0.18362
17 verbose argv "C:\Program Files\nodejs\node.exe" "C:\Program Files\nodejs\node_modules\npm\bin\npm-cli.js" "start"
18 verbose node v12.13.0
19 verbose npm v6.12.0
20 error code ELIFECYCLE
21 error errno 3221226505
22 error node-red@1.0.3 start: node packages/node_modules/node-red/red.js
22 error Exit status 3221226505
23 error Failed at the node-red@1.0.3 start script.
23 error This is probably not a problem with npm. There is likely additional logging output above.
24 verbose exit [ 3221226505, true ]
The log error
