Hi everyone,
I installed the node-red in docker desktop, when I setup a opcua server in the node-red, I can't find the sever using UaExpert which is running in window system, out of the dock desktop. it seems apps in windows can't communicate with apps in docker.
How to connect the apps in docker with the apps in windows? thanks a lots
This isn't really a Node-RED centric question so this forum might not be the best place to pose this question.
Having a quick look into the docker desktop documentation, perhaps this question is what you're looking for.
Thanks all the same! I have get it done by expose the server port.
In your container setup, you need to setup the port used by the ua server (5xxxx) like you did with port 1880 I think.
kind regards
O
