OPCUA SERVER from a Docker. BadCommunicationError
Hello, I installed docker desktop then I installed nodered.
I used the following from NodeRed for this:
    docker run -it -p 1880:1880 -v node_red_data:/data --name mynodered nodered/node-red
Now I want to set up OPCUA server. I installed the necessary pallets for this.
  1. node-red-comtrib-opcua
  2. node-red-contrib-opcua-server
And this is the Flow (from Examples)
Everything looks good, the structure is obviously being built!
so I try to connect to this OPCUA server using UA-Expert, but it doesn't work.
I used “localhost” for the IP address. Port remained the same "54845".
For the IP address i also used "host.docker.internal" but unfortunately not successful either.
I get this message all the time: BadCommunicationError
Is it correct that I use "localhost" as IP address? If not, what else should I use?
Thank you very much!
Ahmad
Do you have a good reason for using docker? If not then I suggest you don't. It can make life difficult as you are finding out.
Hi Colin,
yes I do.
This is my reason:
:sweat_smile:
