I'm sure this will be something on my setup but I thought I'd post it to see if anyone else is getting this? and what (if anything) the DEVs would like me to try / check before I rebuild / repair.
Normally I don't use IE11 but as it was recently posted, my CRON+ node doesn't show on IE I thought as I'm stood down from work (bloody coronavirus) I shall attempt to fix it.
So I fired up IE11 on my dev laptop and this is what I see...
NOTES
- Node v10.15.3
- NPM 6.13.7
- node-red 1.0.0.beta-4
I note you're on a beta release - 1.0.0-beta.3.
I know some IE11 fixes went in after that. You may want to upgrade to a stable release and double check if its reproducable.
No bother Nick, will update & feedback.
PS. its all ok in chrome.
PS2, it was beta.4
if that makes any difference?
So updating to node-red v1.0.4 seems to have solved the IE11 issue - but also some of my locally installed nodes have disapeared. Will re-install one at a time and check again.
If something messes IE up again, I will let you all know which node is the culprit
Can't see the problem - looks normal to me
Julian, that's part of getting past 60
To be honest, I've attended so many COVID related emergency meetings today and spent so long with headphones on staring at the screen that I'm surprised I can see anything at all!
Potentially something was messed up on my laptop - but ultimately updating NR to 1.0.4 solved this. Cheers.
