at first, many thanks for this great node for managing a zwave network!
I have migrated form openwave to zwave js and realy appreciate the new performance and also the capability to manage ZW network directly form NR UI !
However i found an issue on how the event filter node works. I need to do a strict filter by check "strict" flag in a rule but this change nothing about the event filter node behavior, endpoint value is never taken into account. I tooke a look in the code and made a correction into. The corrected code is attached (see at lines 39, 91, 96, 104 and 117).
Hope this is correct
event-filter.js.txt (2.7 KB)
@Francky
Many thanks for looking at this.
I will review shortly and look to implement the fix in my 6.4.0 branch.
once again - thank you
@Francky
Nice!
didn't spot that - asking for strict on the nodes config as apposed to the rule.
I am working on 6.4.0, so will get this fix in there - Once again Thank you.
I am waiting for a replacement dev computer (i pushed the old one to its limit)
once its here, I'll release 6.4.0.
Perfect !
Having strict parameter per rule is realy the better solution !
Have fun with your new PC
Thank you for this futur release
Yup, the strict flag is designed per rule, but for some crazy reason, I was trying to get at it, on the config object.
