I can hear the sounds depending on the variables through the PC. (thanks to Audio Out). But I can't hear these sounds on the Pi. Do you know of a different method or plugin?
What node are you using to play the sounds?
What OS and version are you running on the Pi?
Dashboard Audio Out
Raspberry Pi 4 Model B last OS
It works in browsers on Windows, but not in choronium, which I open on the Pi.
what is the exact node name? i.e. node-red-???????
by last OS do you mean 'Buster'?
Are you running the desktop version on the pi?
what is the exact node name? i.e. node-red-??????? - audio out
by last OS do you mean 'Buster'? -
PRETTY_NAME="Raspbian GNU/Linux 10 (buster)"
NAME="Raspbian GNU/Linux"
VERSION_ID="10"
VERSION="10 (buster)"
VERSION_CODENAME=buster
Are you running the desktop version on the pi? - Yes
