The program imported in the new version of node-red software (the program runs well on the old version of the software). The node display configuration is incorrect. What's the reason?
Please clarify what you mean.
Which 2 versions are you comparing?
Data stream compiled in low version node-red software environment is placed in high version node-red software environment. The function node display configuration is incorrect.
In what way is it incorrect?
Can you provide a screenshot that shows the problem?
The problem has been solved. Thank you.
Can you provide a summary of what was wrong / how you fixed it? Then if other people search and find this thread it can be helpful to them.
