I too am getting the single line function node. (edit: It's happening in comment nodes too)
I upgrade my install of node-red 10 minutes ago from the time of this posting.
I have node-red installed with the non standard root set in the settings.js file. Might that be the problem?
the setting is httpRoot: '/red'
I also have the setting for static files set to httpStatic: '/var/www/nrstatic/'
Does the URL for that script take into account the non standard root location?
I looked in my console and the only error I see is the
"Loading failed for the <script> with source āhttps://cdnjs.cloudflare.com/ajax/libs/ace/1.2.3/mode-nrjavascript.jsā."
The only other error that appears is
"Password fields present on an insecure (http://) page. This is a security risk that allows user login credentials to be stolen."
And that only appears when I double click the function node to open it for editing.
additional:
Just checked the source of the page. The request for the mode-nrjavascript.js file doesn't appear in the page source straight from the server. it appears in the generated source as viewed in the debugger console. (Firefox, in this instance)
the request for that script from the CDN is the only instance that appears in the page source that I viewed
<head>
<style id="autocompletion.css">.ace_editor.ace_autocomplete .ace_marker-layer .ace_active-line { background-color: #CAD6FA; z-index: 1;}.ace_dark.ace_editor.ace_autocomplete .ace_marker-layer .ace_active-line { background-color: #3a674e;}.ace_editor.ace_autocomplete .ace_line-hover { border: 1px solid #abbffe; margin-top: -1px; background: rgba(233,233,253,0.4); position: absolute; z-index: 2;}.ace_dark.ace_editor.ace_autocomplete .ace_line-hover { border: 1px solid rgba(109, 150, 13, 0.8); background: rgba(58, 103, 78, 0.62);}.ace_completion-meta { opacity: 0.5; margin: 0.9em;}.ace_editor.ace_autocomplete .ace_completion-highlight{ color: #2d69c7;}.ace_dark.ace_editor.ace_autocomplete .ace_completion-highlight{ color: #93ca12;}.ace_editor.ace_autocomplete { width: 300px; z-index: 200000; border: 1px lightgray solid; position: fixed; box-shadow: 2px 3px 5px rgba(0,0,0,.2); line-height: 1.4; background: #fefefe; color: #111;}.ace_dark.ace_editor.ace_autocomplete { border: 1px #484747 solid; box-shadow: 2px 3px 5px rgba(0, 0, 0, 0.51); line-height: 1.4; background: #25282c; color: #c1c1c1;}
/*# sourceURL=ace/css/autocompletion.css */</style>
<style>.ace_snippet-marker { -moz-box-sizing: border-box; box-sizing: border-box; background: rgba(194, 193, 208, 0.09); border: 1px dotted rgba(211, 208, 235, 0.62); position: absolute;}</style>
<style>
.error_widget_wrapper { background: inherit; color: inherit; border:none } .error_widget { border-top: solid 2px; border-bottom: solid 2px; margin: 5px 0; padding: 10px 40px; white-space: pre-wrap; } .error_widget.ace_error, .error_widget_arrow.ace_error{ border-color: #ff5a5a } .error_widget.ace_warning, .error_widget_arrow.ace_warning{ border-color: #F1D817 } .error_widget.ace_info, .error_widget_arrow.ace_info{ border-color: #5a5a5a } .error_widget.ace_ok, .error_widget_arrow.ace_ok{ border-color: #5aaa5a } .error_widget_arrow { position: absolute; border: solid 5px; border-top-color: transparent!important; border-right-color: transparent!important; border-left-color: transparent!important; top: -5px; }</style>
<style id="ace-tm">.ace-tm .ace_gutter {background: #f0f0f0;color: #333;}.ace-tm .ace_print-margin {width: 1px;background: #e8e8e8;}.ace-tm .ace_fold {background-color: #6B72E6;}.ace-tm {background-color: #FFFFFF;color: black;}.ace-tm .ace_cursor {color: black;}.ace-tm .ace_invisible {color: rgb(191, 191, 191);}.ace-tm .ace_storage,.ace-tm .ace_keyword {color: blue;}.ace-tm .ace_constant {color: rgb(197, 6, 11);}.ace-tm .ace_constant.ace_buildin {color: rgb(88, 72, 246);}.ace-tm .ace_constant.ace_language {color: rgb(88, 92, 246);}.ace-tm .ace_constant.ace_library {color: rgb(6, 150, 14);}.ace-tm .ace_invalid {background-color: rgba(255, 0, 0, 0.1);color: red;}.ace-tm .ace_support.ace_function {color: rgb(60, 76, 114);}.ace-tm .ace_support.ace_constant {color: rgb(6, 150, 14);}.ace-tm .ace_support.ace_type,.ace-tm .ace_support.ace_class {color: rgb(109, 121, 222);}.ace-tm .ace_keyword.ace_operator {color: rgb(104, 118, 135);}.ace-tm .ace_string {color: rgb(3, 106, 7);}.ace-tm .ace_comment {color: rgb(76, 136, 107);}.ace-tm .ace_comment.ace_doc {color: rgb(0, 102, 255);}.ace-tm .ace_comment.ace_doc.ace_tag {color: rgb(128, 159, 191);}.ace-tm .ace_constant.ace_numeric {color: rgb(0, 0, 205);}.ace-tm .ace_variable {color: rgb(49, 132, 149);}.ace-tm .ace_xml-pe {color: rgb(104, 104, 91);}.ace-tm .ace_entity.ace_name.ace_function {color: #0000A2;}.ace-tm .ace_heading {color: rgb(12, 7, 255);}.ace-tm .ace_list {color:rgb(185, 6, 144);}.ace-tm .ace_meta.ace_tag {color:rgb(0, 22, 142);}.ace-tm .ace_string.ace_regex {color: rgb(255, 0, 0)}.ace-tm .ace_marker-layer .ace_selection {background: rgb(181, 213, 255);}.ace-tm.ace_multiselect .ace_selection.ace_start {box-shadow: 0 0 3px 0px white;}.ace-tm .ace_marker-layer .ace_step {background: rgb(252, 255, 0);}.ace-tm .ace_marker-layer .ace_stack {background: rgb(164, 229, 101);}.ace-tm .ace_marker-layer .ace_bracket {margin: -1px 0 0 -1px;border: 1px solid rgb(192, 192, 192);}.ace-tm .ace_marker-layer .ace_active-line {background: rgba(0, 0, 0, 0.07);}.ace-tm .ace_gutter-active-line {background-color : #dcdcdc;}.ace-tm .ace_marker-layer .ace_selected-word {background: rgb(250, 250, 255);border: 1px solid rgb(200, 200, 250);}.ace-tm .ace_indent-guide {background: url("data:image/png;base64,iVBORw0KGgoAAAANSUhEUgAAAAEAAAACCAYAAACZgbYnAAAAE0lEQVQImWP4////f4bLly//BwAmVgd1/w11/gAAAABJRU5ErkJggg==") right repeat-y;}
/*# sourceURL=ace/css/ace-tm */</style>
<style id="ace_editor.css">.ace_br1 {border-top-left-radius : 3px;}.ace_br2 {border-top-right-radius : 3px;}.ace_br3 {border-top-left-radius : 3px; border-top-right-radius: 3px;}.ace_br4 {border-bottom-right-radius: 3px;}.ace_br5 {border-top-left-radius : 3px; border-bottom-right-radius: 3px;}.ace_br6 {border-top-right-radius : 3px; border-bottom-right-radius: 3px;}.ace_br7 {border-top-left-radius : 3px; border-top-right-radius: 3px; border-bottom-right-radius: 3px;}.ace_br8 {border-bottom-left-radius : 3px;}.ace_br9 {border-top-left-radius : 3px; border-bottom-left-radius: 3px;}.ace_br10{border-top-right-radius : 3px; border-bottom-left-radius: 3px;}.ace_br11{border-top-left-radius : 3px; border-top-right-radius: 3px; border-bottom-left-radius: 3px;}.ace_br12{border-bottom-right-radius: 3px; border-bottom-left-radius: 3px;}.ace_br13{border-top-left-radius : 3px; border-bottom-right-radius: 3px; border-bottom-left-radius: 3px;}.ace_br14{border-top-right-radius : 3px; border-bottom-right-radius: 3px; border-bottom-left-radius: 3px;}.ace_br15{border-top-left-radius : 3px; border-top-right-radius: 3px; border-bottom-right-radius: 3px; border-bottom-left-radius: 3px;}.ace_editor {position: relative;overflow: hidden;font: 12px/normal 'Monaco', 'Menlo', 'Ubuntu Mono', 'Consolas', 'source-code-pro', monospace;direction: ltr;text-align: left;-webkit-tap-highlight-color: rgba(0, 0, 0, 0);}.ace_scroller {position: absolute;overflow: hidden;top: 0;bottom: 0;background-color: inherit;-ms-user-select: none;-moz-user-select: none;-webkit-user-select: none;user-select: none;cursor: text;}.ace_content {position: absolute;box-sizing: border-box;min-width: 100%;contain: style size layout;}.ace_dragging .ace_scroller:before{position: absolute;top: 0;left: 0;right: 0;bottom: 0;content: '';background: rgba(250, 250, 250, 0.01);z-index: 1000;}.ace_dragging.ace_dark .ace_scroller:before{background: rgba(0, 0, 0, 0.01);}.ace_selecting, .ace_selecting * {cursor: text !important;}.ace_gutter {position: absolute;overflow : hidden;width: auto;top: 0;bottom: 0;left: 0;cursor: default;z-index: 4;-ms-user-select: none;-moz-user-select: none;-webkit-user-select: none;user-select: none;contain: style size layout;}.ace_gutter-active-line {position: absolute;left: 0;right: 0;}.ace_scroller.ace_scroll-left {box-shadow: 17px 0 16px -16px rgba(0, 0, 0, 0.4) inset;}.ace_gutter-cell {position: absolute;top: 0;left: 0;right: 0;padding-left: 19px;padding-right: 6px;background-repeat: no-repeat;}.ace_gutter-cell.ace_error {background-image: url("data:image/png;base64,iVBORw0KGgoAAAANSUhEUgAAABAAAAAQCAMAAAAoLQ9TAAABOFBMVEX/////////QRswFAb/Ui4wFAYwFAYwFAaWGAfDRymzOSH/PxswFAb/SiUwFAYwFAbUPRvjQiDllog5HhHdRybsTi3/Tyv9Tir+Syj/UC3////XurebMBIwFAb/RSHbPx/gUzfdwL3kzMivKBAwFAbbvbnhPx66NhowFAYwFAaZJg8wFAaxKBDZurf/RB6mMxb/SCMwFAYwFAbxQB3+RB4wFAb/Qhy4Oh+4QifbNRcwFAYwFAYwFAb/QRzdNhgwFAYwFAbav7v/Uy7oaE68MBK5LxLewr/r2NXewLswFAaxJw4wFAbkPRy2PyYwFAaxKhLm1tMwFAazPiQwFAaUGAb/QBrfOx3bvrv/VC/maE4wFAbRPBq6MRO8Qynew8Dp2tjfwb0wFAbx6eju5+by6uns4uH9/f36+vr/GkHjAAAAYnRSTlMAGt+64rnWu/bo8eAA4InH3+DwoN7j4eLi4xP99Nfg4+b+/u9B/eDs1MD1mO7+4PHg2MXa347g7vDizMLN4eG+Pv7i5evs/v79yu7S3/DV7/498Yv24eH+4ufQ3Ozu/v7+y13sRqwAAADLSURBVHjaZc/XDsFgGIBhtDrshlitmk2IrbHFqL2pvXf/+78DPokj7+Fz9qpU/9UXJIlhmPaTaQ6QPaz0mm+5gwkgovcV6GZzd5JtCQwgsxoHOvJO15kleRLAnMgHFIESUEPmawB9ngmelTtipwwfASilxOLyiV5UVUyVAfbG0cCPHig+GBkzAENHS0AstVF6bacZIOzgLmxsHbt2OecNgJC83JERmePUYq8ARGkJx6XtFsdddBQgZE2nPR6CICZhawjA4Fb/chv+399kfR+MMMDGOQAAAABJRU5ErkJggg==");background-repeat: no-repeat;background-position: 2px center;}.ace_gutter-cell.ace_warning {background-image: url("data:image/png;base64,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");background-position: 2px center;}.ace_gutter-cell.ace_info {background-image: url("data:image/png;base64,iVBORw0KGgoAAAANSUhEUgAAABAAAAAQCAAAAAA6mKC9AAAAGXRFWHRTb2Z0d2FyZQBBZG9iZSBJbWFnZVJlYWR5ccllPAAAAAJ0Uk5TAAB2k804AAAAPklEQVQY02NgIB68QuO3tiLznjAwpKTgNyDbMegwisCHZUETUZV0ZqOquBpXj2rtnpSJT1AEnnRmL2OgGgAAIKkRQap2htgAAAAASUVORK5CYII=");background-position: 2px center;}.ace_dark .ace_gutter-cell.ace_info {background-image: url("data:image/png;base64,iVBORw0KGgoAAAANSUhEUgAAABAAAAAQBAMAAADt3eJSAAAAJFBMVEUAAAChoaGAgIAqKiq+vr6tra1ZWVmUlJSbm5s8PDxubm56enrdgzg3AAAAAXRSTlMAQObYZgAAAClJREFUeNpjYMAPdsMYHegyJZFQBlsUlMFVCWUYKkAZMxZAGdxlDMQBAG+TBP4B6RyJAAAAAElFTkSuQmCC");}.ace_scrollbar {contain: strict;position: absolute;right: 0;bottom: 0;z-index: 6;}.ace_scrollbar-inner {position: absolute;cursor: text;left: 0;top: 0;}.ace_scrollbar-v{overflow-x: hidden;overflow-y: scroll;top: 0;}.ace_scrollbar-h {overflow-x: scroll;overflow-y: hidden;left: 0;}.ace_print-margin {position: absolute;height: 100%;}.ace_text-input {position: absolute;z-index: 0;width: 0.5em;height: 1em;opacity: 0;background: transparent;-moz-appearance: none;appearance: none;border: none;resize: none;outline: none;overflow: hidden;font: inherit;padding: 0 1px;margin: 0 -1px;contain: strict;-ms-user-select: text;-moz-user-select: text;-webkit-user-select: text;user-select: text;white-space: pre!important;}.ace_text-input.ace_composition {background: transparent;color: inherit;z-index: 1000;opacity: 1;}.ace_composition_placeholder { color: transparent }.ace_composition_marker { border-bottom: 1px solid;position: absolute;border-radius: 0;margin-top: 1px;}[ace_nocontext=true] {transform: none!important;filter: none!important;perspective: none!important;clip-path: none!important;mask : none!important;contain: none!important;perspective: none!important;mix-blend-mode: initial!important;z-index: auto;}.ace_layer {z-index: 1;position: absolute;overflow: hidden;word-wrap: normal;white-space: pre;height: 100%;width: 100%;box-sizing: border-box;pointer-events: none;}.ace_gutter-layer {position: relative;width: auto;text-align: right;pointer-events: auto;height: 1000000px;contain: style size layout;}.ace_text-layer {font: inherit !important;position: absolute;height: 1000000px;width: 1000000px;contain: style size layout;}.ace_text-layer > .ace_line, .ace_text-layer > .ace_line_group {contain: style size layout;position: absolute;top: 0;left: 0;right: 0;}.ace_hidpi .ace_text-layer,.ace_hidpi .ace_gutter-layer,.ace_hidpi .ace_content,.ace_hidpi .ace_gutter {contain: strict;will-change: transform;}.ace_hidpi .ace_text-layer > .ace_line, .ace_hidpi .ace_text-layer > .ace_line_group {contain: strict;}.ace_cjk {display: inline-block;text-align: center;}.ace_cursor-layer {z-index: 4;}.ace_cursor {z-index: 4;position: absolute;box-sizing: border-box;border-left: 2px solid;transform: translatez(0);}.ace_multiselect .ace_cursor {border-left-width: 1px;}.ace_slim-cursors .ace_cursor {border-left-width: 1px;}.ace_overwrite-cursors .ace_cursor {border-left-width: 0;border-bottom: 1px solid;}.ace_hidden-cursors .ace_cursor {opacity: 0.2;}.ace_smooth-blinking .ace_cursor {transition: opacity 0.18s;}.ace_animate-blinking .ace_cursor {animation-duration: 1000ms;animation-timing-function: step-end;animation-name: blink-ace-animate;animation-iteration-count: infinite;}.ace_animate-blinking.ace_smooth-blinking .ace_cursor {animation-duration: 1000ms;animation-timing-function: ease-in-out;animation-name: blink-ace-animate-smooth;}@keyframes blink-ace-animate {from, to { opacity: 1; }60% { opacity: 0; }}@keyframes blink-ace-animate-smooth {from, to { opacity: 1; }45% { opacity: 1; }60% { opacity: 0; }85% { opacity: 0; }}.ace_marker-layer .ace_step, .ace_marker-layer .ace_stack {position: absolute;z-index: 3;}.ace_marker-layer .ace_selection {position: absolute;z-index: 5;}.ace_marker-layer .ace_bracket {position: absolute;z-index: 6;}.ace_marker-layer .ace_active-line {position: absolute;z-index: 2;}.ace_marker-layer .ace_selected-word {position: absolute;z-index: 4;box-sizing: border-box;}.ace_line .ace_fold {box-sizing: border-box;display: inline-block;height: 11px;margin-top: -2px;vertical-align: middle;background-image:url("data:image/png;base64,iVBORw0KGgoAAAANSUhEUgAAABEAAAAJCAYAAADU6McMAAAAGXRFWHRTb2Z0d2FyZQBBZG9iZSBJbWFnZVJlYWR5ccllPAAAAJpJREFUeNpi/P//PwOlgAXGYGRklAVSokD8GmjwY1wasKljQpYACtpCFeADcHVQfQyMQAwzwAZI3wJKvCLkfKBaMSClBlR7BOQikCFGQEErIH0VqkabiGCAqwUadAzZJRxQr/0gwiXIal8zQQPnNVTgJ1TdawL0T5gBIP1MUJNhBv2HKoQHHjqNrA4WO4zY0glyNKLT2KIfIMAAQsdgGiXvgnYAAAAASUVORK5CYII="),url("data:image/png;base64,iVBORw0KGgoAAAANSUhEUgAAAAEAAAA3CAYAAADNNiA5AAAAGXRFWHRTb2Z0d2FyZQBBZG9iZSBJbWFnZVJlYWR5ccllPAAAACJJREFUeNpi+P//fxgTAwPDBxDxD078RSX+YeEyDFMCIMAAI3INmXiwf2YAAAAASUVORK5CYII=");background-repeat: no-repeat, repeat-x;background-position: center center, top left;color: transparent;border: 1px solid black;border-radius: 2px;cursor: pointer;pointer-events: auto;}.ace_dark .ace_fold {}.ace_fold:hover{background-image:url("data:image/png;base64,iVBORw0KGgoAAAANSUhEUgAAABEAAAAJCAYAAADU6McMAAAAGXRFWHRTb2Z0d2FyZQBBZG9iZSBJbWFnZVJlYWR5ccllPAAAAJpJREFUeNpi/P//PwOlgAXGYGRklAVSokD8GmjwY1wasKljQpYACtpCFeADcHVQfQyMQAwzwAZI3wJKvCLkfKBaMSClBlR7BOQikCFGQEErIH0VqkabiGCAqwUadAzZJRxQr/0gwiXIal8zQQPnNVTgJ1TdawL0T5gBIP1MUJNhBv2HKoQHHjqNrA4WO4zY0glyNKLT2KIfIMAAQsdgGiXvgnYAAAAASUVORK5CYII="),url("data:image/png;base64,iVBORw0KGgoAAAANSUhEUgAAAAEAAAA3CAYAAADNNiA5AAAAGXRFWHRTb2Z0d2FyZQBBZG9iZSBJbWFnZVJlYWR5ccllPAAAACBJREFUeNpi+P//fz4TAwPDZxDxD5X4i5fLMEwJgAADAEPVDbjNw87ZAAAAAElFTkSuQmCC");}.ace_tooltip {background-color: #FFF;background-image: linear-gradient(to bottom, transparent, rgba(0, 0, 0, 0.1));border: 1px solid gray;border-radius: 1px;box-shadow: 0 1px 2px rgba(0, 0, 0, 0.3);color: black;max-width: 100%;padding: 3px 4px;position: fixed;z-index: 999999;box-sizing: border-box;cursor: default;white-space: pre;word-wrap: break-word;line-height: normal;font-style: normal;font-weight: normal;letter-spacing: normal;pointer-events: none;}.ace_folding-enabled > .ace_gutter-cell {padding-right: 13px;}.ace_fold-widget {box-sizing: border-box;margin: 0 -12px 0 1px;display: none;width: 11px;vertical-align: top;background-image: url("data:image/png;base64,iVBORw0KGgoAAAANSUhEUgAAAAUAAAAFCAYAAACNbyblAAAANElEQVR42mWKsQ0AMAzC8ixLlrzQjzmBiEjp0A6WwBCSPgKAXoLkqSot7nN3yMwR7pZ32NzpKkVoDBUxKAAAAABJRU5ErkJggg==");background-repeat: no-repeat;background-position: center;border-radius: 3px;border: 1px solid transparent;cursor: pointer;}.ace_folding-enabled .ace_fold-widget {display: inline-block; }.ace_fold-widget.ace_end {background-image: url("data:image/png;base64,iVBORw0KGgoAAAANSUhEUgAAAAUAAAAFCAYAAACNbyblAAAANElEQVR42m3HwQkAMAhD0YzsRchFKI7sAikeWkrxwScEB0nh5e7KTPWimZki4tYfVbX+MNl4pyZXejUO1QAAAABJRU5ErkJggg==");}.ace_fold-widget.ace_closed {background-image: url("data:image/png;base64,iVBORw0KGgoAAAANSUhEUgAAAAMAAAAGCAYAAAAG5SQMAAAAOUlEQVR42jXKwQkAMAgDwKwqKD4EwQ26sSOkVWjgIIHAzPiCgaqiqnJHZnKICBERHN194O5b9vbLuAVRL+l0YWnZAAAAAElFTkSuQmCCXA==");}.ace_fold-widget:hover {border: 1px solid rgba(0, 0, 0, 0.3);background-color: rgba(255, 255, 255, 0.2);box-shadow: 0 1px 1px rgba(255, 255, 255, 0.7);}.ace_fold-widget:active {border: 1px solid rgba(0, 0, 0, 0.4);background-color: rgba(0, 0, 0, 0.05);box-shadow: 0 1px 1px rgba(255, 255, 255, 0.8);}.ace_dark .ace_fold-widget {background-image: url("data:image/png;base64,iVBORw0KGgoAAAANSUhEUgAAAAUAAAAFCAYAAACNbyblAAAAHklEQVQIW2P4//8/AzoGEQ7oGCaLLAhWiSwB146BAQCSTPYocqT0AAAAAElFTkSuQmCC");}.ace_dark .ace_fold-widget.ace_end {background-image: url("data:image/png;base64,iVBORw0KGgoAAAANSUhEUgAAAAUAAAAFCAYAAACNbyblAAAAH0lEQVQIW2P4//8/AxQ7wNjIAjDMgC4AxjCVKBirIAAF0kz2rlhxpAAAAABJRU5ErkJggg==");}.ace_dark .ace_fold-widget.ace_closed {background-image: url("data:image/png;base64,iVBORw0KGgoAAAANSUhEUgAAAAMAAAAFCAYAAACAcVaiAAAAHElEQVQIW2P4//+/AxAzgDADlOOAznHAKgPWAwARji8UIDTfQQAAAABJRU5ErkJggg==");}.ace_dark .ace_fold-widget:hover {box-shadow: 0 1px 1px rgba(255, 255, 255, 0.2);background-color: rgba(255, 255, 255, 0.1);}.ace_dark .ace_fold-widget:active {box-shadow: 0 1px 1px rgba(255, 255, 255, 0.2);}.ace_inline_button {border: 1px solid lightgray;display: inline-block;margin: -1px 8px;padding: 0 5px;pointer-events: auto;cursor: pointer;}.ace_inline_button:hover {border-color: gray;background: rgba(200,200,200,0.2);display: inline-block;pointer-events: auto;}.ace_fold-widget.ace_invalid {background-color: #FFB4B4;border-color: #DE5555;}.ace_fade-fold-widgets .ace_fold-widget {transition: opacity 0.4s ease 0.05s;opacity: 0;}.ace_fade-fold-widgets:hover .ace_fold-widget {transition: opacity 0.05s ease 0.05s;opacity:1;}.ace_underline {text-decoration: underline;}.ace_bold {font-weight: bold;}.ace_nobold .ace_bold {font-weight: normal;}.ace_italic {font-style: italic;}.ace_error-marker {background-color: rgba(255, 0, 0,0.2);position: absolute;z-index: 9;}.ace_highlight-marker {background-color: rgba(255, 255, 0,0.2);position: absolute;z-index: 8;}.ace_text-input-ios {position: absolute !important;top: -100000px !important;left: -100000px !important;}
/*# sourceURL=ace/css/ace_editor.css */</style>
<meta charset="utf-8">
<meta http-equiv="X-UA-Compatible" content="IE=edge">
<meta name="viewport" content="width=device-width, initial-scale=1, maximum-scale=1, user-scalable=0">
<meta name="apple-mobile-web-app-capable" content="yes">
<meta name="mobile-web-app-capable" content="yes">
Copyright JS Foundation and other contributors, http://js.foundation
Licensed under the Apache License, Version 2.0 (the "License");
you may not use this file except in compliance with the License.
You may obtain a copy of the License at
http://www.apache.org/licenses/LICENSE-2.0
Unless required by applicable law or agreed to in writing, software
distributed under the License is distributed on an "AS IS" BASIS,
WITHOUT WARRANTIES OR CONDITIONS OF ANY KIND, either express or implied.
See the License for the specific language governing permissions and
limitations under the License.
<title>Node-RED : 192.168.0.18</title>
<link rel="icon" type="image/png" href="favicon.ico">
<link rel="mask-icon" href="red/images/node-red-icon-black.svg" color="#8f0000">
<link href="vendor/bootstrap/css/bootstrap.min.css" rel="stylesheet" media="screen">
<link href="vendor/jquery/css/smoothness/jquery-ui-1.10.3.custom.min.css" rel="stylesheet" media="screen">
<link rel="stylesheet" href="vendor/font-awesome/css/font-awesome.min.css">
<link rel="stylesheet" href="vendor/vendor.css">
<link rel="stylesheet" href="red/style.min.css">
<script type="text/javascript" src="blocky/js/lib/basic/blockly_compressed.js"></script>
<script type="text/javascript" src="blocky/js/lib/basic/msg/messages.js"></script>
<script type="text/javascript" src="blocky/js/lib/basic/blocks_compressed.js"></script>
<script type="text/javascript" src="blocky/js/lib/basic/javascript_compressed.js"></script>
<script type="text/javascript" src="blocky/js/lib/basic/msg/js/en.js"></script>
<script type="text/javascript" src="blocky/js/messages/en.js"></script>
<script type="text/javascript" src="blocky/js/lib/json/objectBlocksCodeGen.js"></script>
<script type="text/javascript" src="blocky/js/lib/json/objectBlocksDefs.js"></script>
<script type="text/javascript" src="blocky/js/lib/nodered/nodeRedBlocksCodeGen.js"></script>
<script type="text/javascript" src="blocky/js/lib/nodered/nodeRedBlocksDefs.js"></script>
<script type="text/javascript" src="blocky/js/lib/extra/extraBlocksCodeGen.js"></script>
<script type="text/javascript" src="blocky/js/lib/extra/extraBlocksDefs.js"></script>
<script type="text/javascript" src="blocky/js/lib/buffer/bufferBlocksCodeGen.js"></script>
<script type="text/javascript" src="blocky/js/lib/buffer/bufferBlocksDefs.js"></script>
<script type="text/javascript" src="blocky/js/lib/datetime/dateTimeBlocksCodeGen.js"></script>
<script type="text/javascript" src="blocky/js/lib/datetime/dateTimeBlocksDefs.js"></script>
<script src="https://cdnjs.cloudflare.com/ajax/libs/ace/1.2.3/theme-tomorrow.js"></script>
<script src="https://cdnjs.cloudflare.com/ajax/libs/ace/1.2.3/mode-markdown.js"></script>
<script src="https://cdnjs.cloudflare.com/ajax/libs/ace/1.2.3/mode-nrjavascript.js"></script>
