hi, is there a way to sync a folder on nextcloud with a folder on the Raspberry using "@kuehnelbs/node-red-contrib-nextcloud"? Has anyone here ever created a flow?
Since there are many unaddressed issues on the node's github page I would avoid that node. Even if you get it working now the fact that it is not supported means it will probably stop working at some point.
Thank you very much for your feedback. Is there a way to copy WHOLE folders from nextcloud to the Raspberry?
Sorry, I don't know, and searching the forum for nextcloud does not suggest that others have successfully accessed nextcloud from node-red.
Wouldn’t you just use their Linux sync client. Nothing to do with Node-RED ?
