I have 2 PCs running WIN 11. Both are on the same sub-net. Both have an instance of Node-Red v4.0.9, Node.js v22.14.0.
The "main" PC is running Homeseer HS4 v4.2.22.4
I have several Red-Node operations that are triggered by HS4, and are working properly.
What I am trying to do, unsuccessfully, is to have an HS4 device trigger a Red-Node flow on the second PC.
The flow appears to be setup properly on the second PC, but no data seems to come over when the HS4 device changes.
I have port 1880 allowed through the ESET firewall
There are multiple methods. You must also decide whether to use a separate user id/password to run it and whether you want it to run on system startup or on user login.
You can use the Windows task scheduler. You could turn the startup into a Windows service. Or you can use a 3rd-party tool.
To be honest, running local services is much easier and more reliable on Linux than Windows Desktop.
OK, I think you need to check whether the Windows Defender local Firewall is also running. It is possible that it is blocking the inbound connection.
More importantly, I forgot to ask how you are making the connection between the two flows? What node are you using to send and what node to receive on the other end?
I've just tried a simple connection between my live Node-RED on Linux and my dev instance on Windows 11. Using an http-request node on the live server and http-in/http-response on the dev machine. It worked perfectly. I don't have a rule port 1880 inbound. But node.exe does have an allow-all inbound rule for private networks. The dev device is a desktop PC on a secured network so this is fine.
It isn't very friendly to be honest. Linux has a lot easier access to monitoring tools in my view (and I am a VERY long-term Windows user).
Just to see if I understand. The end result you are stuggling with is getting the two windows node red instances communicating with another?
You could use mqtt service such a mosquito (this is the most ideal as mqtt has a much more robust capability, but with the new version of mosquito i have had issues getting to work on node-red)
One work around I discovered while using a syslog server is using ncat to send a message from one machine to another under port 514
Palette to install is syslog-input
Command to send to this instance is echo "<34>jan 24 21:11:25 myhostname myapp: {{payload}}" | nc -w 1 -u your ip here
The time stamp in this is arbitrary as you just need to msg format.
This is how i send from linux to windows. For windows to windows you will need to install nmap and direct the terminal command to you ncat file location.
