Hi, i'm new in node red. I'm installed on docker, the container is runnig ok but when I navigate to the page on chrome its shows a blank page.
but if I change to private mode it shows ok, also works fine in edge and firefox.
What i'm doing wrong?
Sounds like you have an extension enabled that breaks node-red. Perhaps an ad blocker it some other rubbish. Disable extensions 1 by 1 & reload the browser until it works.
Also, try a hard refresh (ctrl+f5) or clear the cache.
Thanks Steve, I disabled Epub Reader Extension (!!????) and works fine.
Try enabling it again to make sure it is consistent. If not then it may have been a caching issue.
Yes Colin, I enabled the extension again and the problem returns, all other extensions work fine.
