Performance troubleshooting - specifically delays in deploy
I'd like to reduce the time it takes to redeploy, currently about 12-15 seconds.
When I first started with Node-RED, it took a second or two. I understand it's inevitable that as I do more and more, redeploying will take longer, but wanted to gauge reaction here to see if there's anything I can do.
I have turned on trace logging in settings.js.
Sorry if this is obvious but when there's a delay between two lines, is the culprit the item before the delay, or after?
i.e. which line is the cause of this 2 second delay, the first or second?
5 Jul 21:11:10 - [debug] [server:Home Assistant] config server event listener closed
5 Jul 21:11:12 - [trace] Stopped node telegram bot:14f0fdaf.843b92 (3808ms)
The logs total 3763 lines, so probably best not to post them here? But my observations are:
  • Lines starting "stopping nodes" and "stopped nodes" all happen immediately, no delays
  • There's then a 3 second delay within these lines:
5 Jul 21:11:09 - [info] serial port /home/mat/virtualcom1 closed
5 Jul 21:11:09 - [trace] Stopped node serial out:9e0845b5.f18758 (433ms)
5 Jul 21:11:10 - [debug] [server:Home Assistant] WebSocket Connecting http://10.1.1.37:8123
5 Jul 21:11:10 - [debug] [server:Home Assistant] config server event listener connecting
5 Jul 21:11:12 - [info] Stopped flows
5 Jul 21:11:12 - [info] Starting flows
  • Another 2 second delay here:
5 Jul 21:11:13 - [trace] [flow:fd75c8e.6e63e38] ------------------|--------------|-----------------
5 Jul 21:11:13 - [trace] [flow:a09201df.15c79] start flow
5 Jul 21:11:14 - [debug] [api-current-state:38f8b647.bdac5a] instantiated node, name: undefined
5 Jul 21:11:15 - [trace] [flow:a09201df.15c79] ------------------|--------------|-----------------
5 Jul 21:11:15 - [trace] [flow:a09201df.15c79]  id               | type         | alias
5 Jul 21:11:15 - [trace] [flow:a09201df.15c79]  81881b84.f82358  | ui_button    |
5 Jul 21:11:15 - [trace] [flow:a09201df.15c79]  ffe10c50.9b693   | mqtt out     |
5 Jul 21:11:15 - [trace] [flow:a09201df.15c79]  6a1b328c.364114  | link in      |
5 Jul 21:11:15 - [trace] [flow:705d403b.f2b8] start flow
5 Jul 21:11:17 - [trace] [flow:705d403b.f2b8] ------------------|--------------|-----------------
5 Jul 21:11:17 - [trace] [flow:705d403b.f2b8]  id               | type         | alias
5 Jul 21:11:17 - [trace] [flow:705d403b.f2b8]  91ae1f5b.663d1   | mqtt in      |
5 Jul 21:11:17 - [trace] [flow:705d403b.f2b8]  c044f417.257fb8  | switch       |
  • Again here:
5 Jul 21:11:18 - [trace] [flow:acccd118.a467d]  4727a99a.b67ee   | change       |
5 Jul 21:11:18 - [trace] [flow:acccd118.a467d] ------------------|--------------|-----------------
5 Jul 21:11:18 - [trace] [flow:548d42c.321903c] start flow
5 Jul 21:11:20 - [trace] [flow:548d42c.321903c] ------------------|--------------|-----------------
5 Jul 21:11:20 - [trace] [flow:548d42c.321903c]  id               | type         | alias
5 Jul 21:11:20 - [trace] [flow:548d42c.321903c]  4b8be51d.0c0d54  | telegram sender |
5 Jul 21:11:20 - [trace] [flow:548d42c.321903c]  6a1337c1.a84a88  | link out     |
  • Finally
5 Jul 21:11:20 - [trace] [flow:548d42c.321903c]  2ff263db.d90944  | debug        |
5 Jul 21:11:20 - [trace] runtime event: {"id":"runtime-state","retain":true}
5 Jul 21:11:20 - [info] Started flows
5 Jul 21:11:20 - [trace] runtime event: {"id":"runtime-deploy","payload":{"revision":"79a10748667bdbb944a0cf62c14d60a1"},"retain":true}
5 Jul 21:11:21 - [debug] [server:Home Assistant] WebSocket Connecting http://10.1.1.37:8123
5 Jul 21:11:21 - [debug] [server:Home Assistant] config server event listener connecting
5 Jul 21:11:21 - [debug] Flushing localfilesystem context scope global
5 Jul 21:11:21 - [debug] Flushing localfilesystem context scope b6f158a2.116b88:fa3892e2.c6cfd
Any obvious things I can temporarily remove to test?
Should I just throw more processing power or memory at it?
Node RED is running on Ubuntu in a VM on a Windows host, with 96GB of RAM and XEON processor so I can probably assign more resources, but wanted to check people's initial reactions here first!
Without knowing how big and complex your flow is it is very difficult to gauge how much of a "problem" this is.
Also what kind of deploy are you doing? Full or partial?
Now I feel a bit silly - this is a good point. Far quicker doing a deploy of modified nodes - as in, half a second. Thank you.
OOI - why would you want to do a full deploy?
Occasionally, some nodes really need a kick to get them into shape. Also, a full redeploy should clear out any in-memory data including global/flow variables I think.
I always do a minimal deploy unless something looks wrong afterwards.
