Pi4 - can not access Node Red from :1880
We have been using NodeRed successfully on Pi3.
Recently we are looking at moving to Pi4.
Here is what we have done:
  1. Pi 4 is running Version 11 ( bullseye) as recommended by RPI.
  2. We noticed that NodeRed is not installed on the distribution of bullseye
  3. We installed Node Red on the Pi4 using the recommended curl command
  1. We started the node red by the command 'node-red-start'
Here is the problem:
  1. Opening the local Chromium browser on the PI and entering the standard "127.0.0.1:1880", the browser does not connect to Node Red. The Chromium error states 'this site can not be reached'
As always, as soon as I post the question, we figure out the error.
Here is what happened:
we had edited the 'settings.js' file of node-red to secure the Admin Auth
we left in an extra '/' in the json for the admin.
